[mapserver-users] XBase Question--adding columns to a .dbf file
imap at chesapeake.net
Wed Oct 3 14:54:39 PDT 2001
On the XBase Question about adding columns...
This type of program should work OK. You end up
having to build a new file, but that isnt a bad
thing.
# add_column.pl
use XBase;
my $table = new XBase $ARGV[0] or die XBase->errstr;
my @fn = $table->field_names();
my @ft = $table->field_types();
my @fl = $table->field_lengths();
my @fd = $table->field_decimals();
# HERE you will have to push additional values into each
# of the arrays above. (ie new Columns)
# push @fn, "NEWCOL1","NEWCOL2";
# push @ft, "C","C";
# push @fl, "25","20";
# push @fd, "undef","undef";
my $newtable = XBase->create("name" => $ARGV[1],
"field_names" => [@fn],
"field_types" => [@ft],
"field_lengths" => [@fl],
"field_decimals" => [@fd] );
for $x (0 .. $table->last_record) {
@rec = $table->get_record($x);
next if ($deleted);
# push new data onto @rec or leave empty
$newtable->set_record($x, at rec);
I hope that works for you...
Regards,
Chris Stuber (mapsurfer)
Silicon Mapping Solutions, Inc.
(410)257-3187
> klehr1 at tampabay.rr.com wrote:
> I'd like to add two columns to a current .dbf file using the XBase perl
> module.
> Could someone provide me a small piece of code to accomplish this task.
> I'm not sure of the syntax for XBase to grab a row, chop it into its fields,
> add 2 more fields to the array, repack it into the xbase format then write it
> to a new .dbf (say ARGV[1]).
> i.e. in plain text file say tab delimited
> if (!$ARGV[1])
> print "\n Invalid usage...Usage: add_columns.pl CURRENTFILE NEWFILE\n";
> exit;
> open(INPUT, $ARGV[0]) || die "Could not open $ARGV[0]";
> open(OUTPUT, ">$ARGV[1]");
> while(<INPUT>)
> chomp();
> @fields = split(/\t/, $_); # tab delimited data
> $fields[$#fields + 1] = "new data element 1"; # add an element to the
> array
> $fields[$#fields + 1] = "new data element 2"; # add another element
> print "@fields\n";
> $output_string = join "\t", @fields;
> print OUTPUT "$output_string\n";
> close(INPUT);
> close(OUTPUT);
> I'd like to do the same with .dbfs (append two columns to the current .dbf)
> Thank you
> Steve Lehr
More information about the MapServer-users
