[mapserver-users] PHP, Create Layer on Fly - HELP
Hankley, Chip
Chip.Hankley at GASAI.Com
Tue Oct 16 17:03:36 EDT 2001
Tim,
A couple weeks ago, I had sent a note to the list regarding placing a legend
inside the mapframe dynamically. You asked me to forward you the solution
when I figured it out.
The guys as DMSolutions put up a new dll yesterday - that, along with a
little syntax fix, solved the problem. Function below.
Chip Hankley
________________________________________________________
embed_legend($map, $Cur_Extent, $img);
function embed_legend($map, $Cur_Extent, $img) {
//$map is the current MapObject
//$Cur_Extent is an array where:
//$Cur_Extent[0] = Xmin
//$Cur_Extent[1] = Ymin
//$Cur_Extent[2] = Xmax
//$Cur_Extent[3] = Ymax
//$img is the current ImageObject
//Create a new Point Layer
$layer = ms_newLayerObj($map);
$layer->set("name", "legend");
$layer->set("type", MS_LAYER_POINT);
$layer->set("status", 1);
//Create a new Class for the Layer
$class = ms_newClassObj($layer);
$class->set("name", "legendclass");
$symb = $map->getSymbolByName('symbols/legend.png');
$class->set("symbol", $symb);
//Place the point so that it is 52 pixels IN and 41
// pixels UP from the lower left hand conrner of
// the image. We are using an image that is 100 x 80
// pixels... this should put the image just inside
// the rendered image.
$ImgWidth = $map->width;
$ImgHeight = $map->height;
$Pixel_X = ($Cur_Extent[2] - $Cur_Extent[0]) / $ImgWidth;
$Pixel_Y = ($Cur_Extent[3] - $Cur_Extent[1]) / $ImgHeight;
$Spot_X = $Cur_Extent[0] + 52 * $Pixel_X;
$Spot_Y = $Cur_Extent[1] + 41 * $Pixel_Y;
$point = ms_newpointObj();
$point->setXY($Spot_X, $Spot_Y);
$point->draw($map,$layer,$img,'legendclass',undef);
$layer->draw($img);
