[mapserver-users] Cannot find -lzlib during build with ogr support
Tyler Mitchell
TMitchell at lignum.com
Wed Oct 17 18:17:38 EDT 2001
Thanks Frank, this did the trick.
Frank
Warmerdam To: Tyler Mitchell <TMitchell at lignum.com>
<warmerdam at pob cc: Daniel Morissette <morissette at dmsolutions.ca>
ox.com> Fax to:
Subject: Re: [mapserver-users] Cannot find -lzlib
10/17/01 01:35 during build with ogr support
PM
Please respond
to warmerdam
Tyler Mitchell wrote:
> Boy, you're really gonna make me work on this one eh? ;)
> I downloaded gdal-1.1.5 and ogdi-3.1.0. Yes, I have libzlib_ogdi31.so in
> /usr/local/lib.
> How can I tell if I've got them installed properly. I'm not writing any
> code using the libs myself, but did notice that there were a few
> executables that came along. Are they (i.e. gdaladdo) documented
anywhere?
> Could it be a path setting problem. I have multiple terminal sessions
> running here and am finding it hard to keep my env variables up to date
in
> all of them. I've discovered ldconfig, but can you tell me where to
> permanently set path variables? gdal-config wasn't in my path, but once
I
> fixed that, gdal-config --libs said: -L/usr/local/lib -lgdal.1.1
> Should I still remove the reference, or should I make sure my path and
> ld_library stuff is setup properly and re-try compile?
Tyler,
Just remove "-logdi -lzlib" from your Makefile for now. I see the
configure script is a bit broken with regard to OGDI. I will correct this
by removing the OGDI specific requests in MapServers configure script. At
this point MapServer's configure is supposed to use gdal-config --libs to
find libraries needed by GDAL so speicific knowledge of stuff like OGDI is
not needed.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | Geospatial Programmer for Rent
