[mapserver-users] ms_newLineObj()
Jean-François MONY
jef.mony at free.fr
Wed Oct 31 03:33:16 EST 2001
I have a little problem with the ms_newLineObj() command.
As you can see below I create some points and the goal is to make a polygon
with those points, then I create a line.
With the print_r function I'm sure that the points are well created, but I
can't create the line and I don't understand why.
If somebody have an idea.
I use mapserver 3.5 (nightly build from the begining of september) with php
4.05.
Thanks, Jef
CODE
session_start();
require("../config.php");
function split_string($sql, $delimiter)
$sql = trim($sql);
$buffer = array();
$ret = array();
$in_string = false;
for($i=0; $i<strlen($sql); $i++)
if($sql[$i] == $delimiter && !$in_string)
$ret[] = substr($sql, 0, $i);
$sql = substr($sql, $i + 1);
$i = 0;
if($in_string && ($sql[$i] == $in_string) && $buffer[0] != "\\")
$in_string = false;
elseif(!$in_string && ($sql[$i] == "\"" || $sql[$i] == "'") && $buffer[0] !
$in_string = $sql[$i];
$buffer[0] = $buffer[1];
$buffer[1] = $sql[$i];
if (!empty($sql))
$ret[] = $sql;
return($ret);
$polyarray=split_string($poly, ";");
print("$poly<br>");
$ligne = ms_newLineObj();
for ($i=1; $i<$polyarray[0]+1;$i++)
$j=2*$i-1;
$k=2*$i;
$point=ms_newPointObj();
$point->setXY($polyarray[$j], $polyarray[$k]);
print_r($point);
print("<br>");
$ligne->add($point);
print_r($ligne);
print("<br>");
$shape = ms_newShapeObj(MS_SHAPE_POLYGON);
$shape->add($ligne);
print_r($shape);
print("<br>");
RESULT
4;907249;2505661;909472;2486354;934669;2483012;919847;2504547;
point Object ( [_handle_] => Resource id #2 [x] => 907249 [y] => 2505661 )
line Object ( [_handle_] => Resource id #1 [numpoints] => 0 )
point Object ( [_handle_] => Resource id #3 [x] => 909472 [y] => 2486354 )
point Object ( [_handle_] => Resource id #4 [x] => 934669 [y] => 2483012 )
point Object ( [_handle_] => Resource id #5 [x] => 919847 [y] => 2504547 )
shape Object ( [_handle_] => Resource id #6 [numlines] => 0 [type] => 2 [index]
=> -1 [tileindex] => -1 [classindex] => 0 [numvalues] => 0 [text] => [bounds]
=> rect Object ( [_handle_] => Resource id #7 [minx] => -1 [miny] => -1 [maxx]
=> -1 [maxy] => -1 ) )
