[mapserver-users] Add points to a online map? (FWD)
Paul Ramsey
pramsey at refractions.net
Wed Oct 31 12:39:05 EST 2001
Yes. You might find one way to do this is to use PostGIS to store the
point layer. Jeff is actually putting together a little
Mapserver/PostGIS app right now to do exactly this. All the background
layers are shape files, but the point layer is a db layer, so it is very
easy to add new points to it and edit it. Needless to say, mapscript
coding is definately required. You could also do this using a shape file
to store the points, but could have file integrity problems if you were
ever unlucky enough to get two concurrent edits of the file.
teb wrote:
> Is it possible that a visitor of our website adds a point to our online map
> and also add specific information about the point? Will this change (adding
> a point) be directly visible on the map?
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
