[mapserver-users] Add points to a online map? (FWD)
Searle Ross
Ross.Searle at dnr.qld.gov.au
Wed Oct 31 17:07:12 EST 2001
Paul and Twan,
We have used PostGIS to do just this, without using any mapscripting
just a bit of javascript and perl. This was actually the reason we
started using this great piece of software. The user clicks on the map
and the javascript works out the real world coords and pops up a form.
Info is entered and then added to postgres via an insert using perl.
Next time you view the map the point is there large as life. Sorry I
can't show you the site but it is inside our firewall.
Regards
Ross
-----Original Message-----
From: Paul Ramsey [mailto:pramsey at refractions.net]
Sent: Thursday, 1 November 2001 3:39 AM
To: teb
Cc: mapserver-users at lists.gis.umn.edu; twan at twansoft.com
Subject: Re: [mapserver-users] Add points to a online map? (FWD)
Yes. You might find one way to do this is to use PostGIS to store the
point layer. Jeff is actually putting together a little
Mapserver/PostGIS app right now to do exactly this. All the background
layers are shape files, but the point layer is a db layer, so it is very
easy to add new points to it and edit it. Needless to say, mapscript
coding is definately required. You could also do this using a shape file
to store the points, but could have file integrity problems if you were
ever unlucky enough to get two concurrent edits of the file.
teb wrote:
> Is it possible that a visitor of our website adds a point to our
online map
> and also add specific information about the point? Will this change
(adding
> a point) be directly visible on the map?
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
The information in this e-mail together with any attachments is
intended only for the person or entity to which it is addressed
and may contain confidential and/or privileged material.
Any form of review, disclosure, modification, distribution
and/or publication of this e-mail message is prohibited.
If you have received this message in error, you are asked to
inform the sender as quickly as possible and delete this message
and any copies of this message from your computer and/or your
computer system network.
