[mapserver-users] msCalculateScale() error.
Vinko Vrsalovic B.
v at w.cl
Fri Sep 7 20:17:58 EDT 2001
> I made the change to the scale calculation function to make sure that
> an extent is valid before proceeding. The PHP code most likely needs
> to be upgraded to ignore that error (there are occations when that is
> OK to do) if appropriate. The rest of my testing has shown no ill affects
> to the change.
Yes, I found that out the hard way :-).
I was passing empty values the first time I called setextent().
Now it works as expected.
Thanks,
V. <v at w.cl>
