[mapserver-users] mapfile help
Walt Lin
joemayfair at usa.net
Wed Sep 26 01:08:40 EDT 2001
Hey guys,
I'm having trouble turning on some layers with mapscript. When turning on the "county" layer, mapscript complains, returns a -1 status, and does not turn it on. The strange thing was that it used to, and I'm almost positive I didn't change the mapfile entry for that layer, just added new layers and moved things around. Do you see anything wrong with my mapfile the way it is? I've read the docs but can't seem to figure it out. The layers are tiger files converted to shp. Thanks.
Walt
MAP
STATUS ON
# EXTENT -72.70 41.44 -70.28 42.79
imagecolor 255 255 255
# SIZE 421 281
UNITS dd
FONTSET fonts.list
# MARKERSET marker.sym
LAYER
NAME county
TYPE POLYGON
# TOLERANCE 3
MAXSCALE 4000000
MINSCALE 5000
LABELMAXSCALE 4000000
LABELITEM "NAME"
CLASS
COLOR 255 255 255
BACKGROUNDCOLOR 255 255 255
OUTLINECOLOR 200 200 200
LABEL
ANGLE AUTO
COLOR 0 0 0
TYPE TRUETYPE
FONT arial
SIZE 10
POSITION AUTO
WRAP " "
MINDISTANCE 300
END
END
END
LAYER
NAME states
TYPE POLYGON
#TOLERANCE 3
MAXSCALE 10000000000
MINSCALE 2000000
LABELITEM "Name"
CLASS
COLOR 255 255 255
LABEL
ANGLE AUTO
COLOR 0 0 0
TYPE TRUETYPE
FONT arial
SIZE 10
POSITION AUTO
WRAP " "
MINDISTANCE 300
END
END
END
LAYER
NAME roads
TYPE LINE
MAXSCALE 185000
LABELMAXSCALE 180000
LABELITEM "FENAME"
CLASS
backgroundcolor 255 255 255
COLOR 180 180 180
LABEL
ANGLE AUTO
COLOR 0 0 0
TYPE TRUETYPE
FONT arial
SIZE 10
POSITION AUTO
WRAP " "
MINDISTANCE 300
END
END
END
LAYER
NAME water
TYPE POLYGON
MAXSCALE 4000000
TOLERANCE 3
CLASS
NAME "Water"
COLOR 150 150 255
# BACKGROUNDCOLOR 32 201 201
BACKGROUNDCOLOR 150 150 255
OUTLINECOLOR 150 150 255
END
END # layer
LAYER
NAME kgl
TYPE POLYGON
MAXSCALE 40000
LABELMAXSCALE 40000
LABELITEM "KGLNAME"
CLASS
NAME "Key"
COLOR 0 250 125
LABEL
COLOR 0 0 0
END
END
END
END # end map
