[mapserver-users] dynamic point with reference map
Kieran J. Ames
kames at keyspanenergy.com
Mon Apr 22 15:43:14 EDT 2002
I'd like to inquire about this functionality on the Image being rendered... not
on any reference map.
I've taken a regular map file and added the same kind of arguments as follows to
the URL, but cannot find any change in the map I've created. I use decimal
degrees, so I chose LAT/LON values that are approximately in the center of the
image. (I switched the order of LAT/LON to see if I was wrong there.)
&map_webuser_feature=new&map_webuser_feature_points=-71.965000+43.254000&map_webuser_feature_text=My+House
&map_webuser_feature=new&map_webuser_feature_points=43.254000+-71.965000&map_webuser_feature_text=My+House
Should the above additions to the URL work?
Here's the full URL, but it's behind our firewall and not accessable on the net.
http://mi.keyspanenergy.com:81/mapserv/mapserv.exe?map=%2Fmaps%2Ftmp%2F1019503669885.map&imgext=-71.969000+43.250000+-71.961000+43.258000&imgbox=5+16+477+492&imgxy=5+16&mode=browse&zoom=1&map_webuser_feature=new&map_webuser_feature_points=43.254000+-71.965000&map_webuser_feature_text=My+House
Thanks for any help.
Kieran
http://mapserver.gis.umn.edu/wilma/mapserver-users/0203/msg00182.html
> Re: [mapserver-users] dynamic point with reference map
> * To: <chuck.bokath at air2web.com>, <mapserver-users at lists.gis.umn.edu>
> * Subject: Re: [mapserver-users] dynamic point with reference map
> * From: "Steve Lime" <steve.lime at dnr.state.mn.us>
> * Date: Mon, 11 Mar 2002 17:07:21 -0600
> * Content-Disposition: inline
> You can't add points to a reference map. You can create a map that looks
> like a reference map with a normal call to the mapserver (mode=map). I think
> there may be some confusion as to what a reference map is or isn't. A
> reference map is a component of a web app- period.
> Steve
> Stephen Lime
> Data & Applications Manager
> Minnesota DNR
> 500 Lafayette Road
> St. Paul, MN 55155
> 651-297-2937
> >>> Chuck Bokath <chuck.bokath at air2web.com> 03/11/02 03:48PM >>>
> Hello,
> Can I use a reference map to add points on top of?
> In the cgi world, should I use mode=reference? Such a cgi request would
> look
> something like
> http://someserver/cgi-bin/mapserv?mode=reference&map_webuser_feature=new&map
> _webuser_feature_points=-84.33333+33.333333+map_webuser_feature_text=My+Hous
> e!&...
> Any help would be greatly appreciated.
> br
> chuck
> * Prev by Date: RE: [mapserver-users] ?a red blinking point
> * Next by Date: [mapserver-users] binary does not work with gdal?!
> * Index(es):
> o Chronological
> o Thread
