[mapserver-users] WMS Client difficulties
Daniel Morissette
morissette at dmsolutions.ca
Tue Apr 23 08:08:33 EDT 2002
Hi Debbie,
The error seems to come from the tsadev.speciesanalyst.net server that
you are cascading... it probably doesn't have an "epsg" file (or it's
not found by mapserv.exe). See what you get when you connect to the
server directly and specify an EPSG SRS:
http://tsadev.speciesanalyst.net/cgi-bin/mapserv.exe?map=cntryBound.map&VERSION=1.1.0&REQUEST=GetMap&layers=world&SRS=EPSG:4326
Daniel
Debbie Pagurek wrote:
> Hi, I'm trying to set up a Mapserver .map file that will make use of the WMS client capabilities, but I'm having difficulty.
> I will include my mapfile. The error I am getting is located in the image area itself and it says: msProcessProjection():no system list, errno: 2
> I take this to mean that it is looking for the epsg file, which, on my system, is located in the proj/nad directory where it should be and I have no problems with projections in my other work.
> I can also see the layer that I want to connect to if I just type the connection URL into my browser. Works fine.
> If anyone could shed some light on this I'd really appreciate it.
> Thanks,
> D. Pagurek
> Here's my map file:
> NAME ITISFEAT
> STATUS ON
> SIZE 600 300
> UNITS DD
> SHAPEPATH "data"
> IMAGECOLOR 255 255 255
> #SYMBOLSET symset.sym
> EXTENT -180.0 -90 180.0 90.0
> PROJECTION
> "init=epsg:4269"
> END
> WEB
> IMAGEPATH "/usr/www/httpd/htdocs/mapdata/tmp/"
> IMAGEURL "/mapdata/tmp/"
> TEMPLATE "itisfeat.html"
> METADATA
> "wms_title" "WMS ITIS"
> "wms_onlineresource" "http://linuxgurrl.agr.ca/cgi-bin/mapitis?"
> "wms_srs" "EPSG:4269"
> "wms_abstract" "Point mapping"
> "wms_accesscontraints" "none"
> "wms_addresstype" "postal"
> "wms_address" "960 Carling Ave."
> "wms_city" "Ottawa"
> "wms_stateorprovince" "Ontario"
> "wms_postcode" "K1A 0C6"
> "wms_country" "Canada"
> "wms_contactelectronicmailaddress" "pagurekd at em.agr.ca"
> "wms_contactfacsimiletelephone" "613-759-1937"
> "wms_contactperson" "D. Pagurek"
> "wms_contactorganization" "Agriculture and Agri-Food Canada"
> "wms_contactposition" ""
> "wms_fees" "none"
> "wms_keywordlist" "ITIS"
> END
> END
> LAYER
> NAME world
> TYPE RASTER
> STATUS DEFAULT
> CONNECTIONTYPE WMS
> CONNECTION "http://tsadev.speciesanalyst.net/cgi-bin/mapserv.exe?map=cntryBound.map&VERSION=1.1.0&REQUEST=GetMap&layers=world"
> PROJECTION
> "init=epsg:4269"
> END
> METADATA
> "wms_title" "World"
> "wms_abstract" "world"
> "wms_extent" "-95.0025 48.9992 -94.9975 49.0008"
> "wms_opaque" "1"
> END
> END # LAYER
> END # MAPFILE
