[mapserver-users] Problem with setlayersdrawingorder
Daniel Morissette morissette at dmsolutions.ca
Wed Apr 24 04:53:00 PDT 2002
Stuart,
By looking at the CVS logs, it seems that setLayersDrawingOrder() was
added on 2002-01-17, which is after the 3.5 release.  I can't explain
why it wasn't added at the same time as getLayersDrawingOrder(), but it
seems that you'll have to upgrade to the 3.6 development version if you
want to use it.
Daniel
Stuart.Row at brs.gov.au wrote:
> I have the getlayersdrawingorder function working without drama, but get the following error when I use the setlayersdrawingorder function using MapServer 3.5 and PHP 4.06.
> Call to undefined function: setlayersdrawingorder() in /var/www/mapserv/test.php
> My code is as follows:
> $layerord = array();
> $layerord = $map->getlayersdrawingorder();
> $success = $map->setlayersdrawingorder($layerord);
> I'm not bothering with actually changing the layer order until I can get this going.
> Any advice or help on this issue would be appreciated.
> Thanks in advance,
> Stuart Row
> Bureau of Rural Sciences
> PO Box E11
> Kingston ACT
> Ph: +61 2 6272 4640   Fax: +61 2 6272 4687
> Email: stuart.row at brs.gov.au
More information about the MapServer-users mailing list
