[mapserver-users] Problem with PostGIS layer
Tyler Mitchell
TMitchell at lignum.com
Tue Aug 6 13:29:11 EDT 2002
I'm not sure but I suspect your user: thaechl doesn't have permission? I
would create a db user with the same name as the web server user, giving
him read-only access.
>createuser nobody (or apache)
Then I'd make sure that this user can read the postgis tables
>psql test
#grant select on borderline to nobody;
Maybe that will help. Doing it this way, you don't need to put in a real
system user/password in your map file! Just plunk in "user=nobody"
instead.
Thomas Haechler
<thaechl at geo.unizh.ch> To: mapserver-users <mapserver-users at lists.gis.umn.edu>
Sent by: cc:
owner-mapserver-users at lists. Fax to:
gis.umn.edu Subject: [mapserver-users] Problem with PostGIS layer
08/06/2002 09:17 AM
hello list,
I just start to use postgis with mapserver and can't seem to make it
work. I get a blank browser window and in the source code the following
error message:
MapServer Error in msPOSTGISLayerOpen(): Error parsing POSTGIS
connection information.
Can anyone please tell me what I am missing?
Thank you in advance,
Thomy
P.S.:
I am using php/mapscript version 3.6.1 and this is what I did:
test=# \! createlang plpgsql test
test=# \! psql -d test -f postgis.sql
test=# \! shp2pgsql borderline.shp borderline test | psql test
test=# CREATE INDEX gist_index
test-# ON borderline
test-# USING GIST ( the_geom GIST_GEOMETRY_OPS );
test=# CREATE INDEX oid_index ON borderline ( oid );
test=# VACUUM ANALYZE;
Mapfile:
# testlayer postgresql
LAYER
NAME "borderline2"
CONNECTIONTYPE postgis
CONNECTION "user=thaechl password=***** dbname=test
host=localhost
port=5432"
DATA "the_geom from borderline"
STATUS DEFAULT
TYPE LINE
METADATA
"TITLE" "Grenze SNP"
END #Metadata
CLASS
NAME 'Grenze SNP'
COLOR 220 20 60
SYMBOL 13
SIZE 2
END #Class
END #Layer
THOMAS HAECHLER
Geographic Information Systems Division
Institute of Geography
University of Zurich
Switzerland
thomas.haechler at geo.unizh.ch
