[mapserver-users] Mapscript and Perl CGI::MiniSvr module
Alex Rice
alex_rice at arc.to
Fri Aug 9 01:09:29 EDT 2002
Has anyone messed about with Perl Mapscript and the CGI::MiniSvr module?
Running a CGI perl script and loading the CGI perl module and the
Mapscript perl module has a lot of overhead and will noticeably
slow you down. Yeah I know it's just noise compared to reading
many MB of shapefiles, but another way to consider it is: you
don't want to make your web app any slower than it already is
just by using a plain old CGI script. If it can be worked around.
CGI::MiniSvr is kind of like a temporary mod perl, except it has
nothing to do with Apache DSOs. And it doesn't require Fast CGI.
Instead it forks a mini httpd process and temporarily maintains
the state of the web application. This means that one could do
something like this:
- load the mapscript module (only once).
- load the CGI module (once).
- read the mapserver .map file (once)
- create some other mapserver objects (once)
- fork the mini server.
- then handle a bunch of requests from a particular client on
port xxxxx.
->tweak mapserver objects
->perform queries
->generate maps
->etc
- timeout after a short while, how long depending on the server load.
OK, I haven't actually got it working yet, but I thought it was
neat enough to share.
Alex Rice, Software Developer
Architectural Research Consultants, Inc.
alex_rice at arc.to
alrice at swcp.com
