[mapserver-users] ogr2ogr error
Seamus Thomas Carroll
carrolls at unbc.ca
Mon Aug 12 21:06:39 EDT 2002
It turns out that the quotes around BC are not supported. After this was
pointed out I was able to run the command using,
ogr2ogr -where "PROV_CODE = 59" /home/carrolls/commhealth/bc_uep/
/home/carrolls/commhealth/can_uep/canuep.shp
On Tue, 13 Aug 2002 Antti.Roppola at brs.gov.au wrote:
> Have you tried a process of elimination to find out
> what part of the command is causing the problems?
> cp ../bc_uep/bcuep.shp .
> ogr2ogr -f "ESRI Shapefile" bcuep.shp canuep.shp
> rm canuep.*
> ogr2ogr -f "ESRI Shapefile" ../bc_uep/bcuep.shp canuep.shp
> rm canup.*
> ogr2ogr -where "Prov = 'BC'" bcuep.shp canuep.shp
> etc. etc.
> Antti
> -----Original Message-----
> From: Seamus Thomas Carroll [mailto:carrolls at unbc.ca]
> Sent: Tuesday, 13 August 2002 3:15 AM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [mapserver-users] ogr2ogr error
> Hi,
> I try running ogr2ogr and this is the result I keep getting.
> carrolls:~/commhealth/can_uep> ogr2ogr -f "ESRI Shapefile" -where "Prov =
> 'BC'" ../bc_uep/bcuep.shp canuep.shp
> ERROR 1: Syntax error, 2 extra tokens
> I can't find any details on the error in the internet. Does anyone have
> anyideas on what the erro might be?
Seamus Carroll
