[mapserver-users] php_mapserver_36.dll
Daniel Morissette
morissette at dmsolutions.ca
Mon Aug 26 09:17:04 EDT 2002
This could be caused by a missing DLL on your system (such as libwww or
other DLLs). I would suggest running the DEPENDS.EXE utility (using
Start/Run...) to check the DLLs on which your php_mapscript_36.dll
depends and making sure that they are all present on your system.
DEPENDS.EXE comes preinstalled on WinXP and possibly Win2k... if you
don't have it then you can do a web search to find and download it.
Daniel
> Jason Spangler wrote:
> Any help would be very appreciated!
> I have a Win2K machine with mapserver running fine. Installed PHP
> 4.2.2 and am trying to run php_mspscript_36.dll
> I get the error "Unable to load dynamic library
> c:\php\extensions\php_mapscript_36.dll"
> The dll is in this directory, as well as many others. I can get PDF
> and MSSQL + other extensions to load fine, but will not load
> map_script.
> I have permissions set correctly, and have looked all over for help,
> but none of the solutions I've found cure my problem.
> If anyone could help me, I would appreciate it immensly!
> Thanks,
> Jason Spangler
> Cass County, Michigan
