[mapserver-users] Re: Getting mapserver running on Mac OS X
Raj Singh
rajsingh at attbi.com
Fri Aug 30 04:59:54 EDT 2002
You may be having the obscure problem I had. Perl's libwww installs a binary
called HEAD in /usr/bin. Some fink build stuff needs to use the program
'head', also in /usr/bin. The problem is that OSX is not case-sensitive, so
it gets confused. The old version should still be in /usr/bin, named
'head.old' or something like that. Try switching the names around and see if
your problems go away.
Raj
