[mapserver-users] Scalebar label
Andrew
ahaigh at ic24.net
Tue Feb 5 07:57:26 EST 2002
I'm relatively new to Mapserver and I'm attempting to implement Mapserver as on OGC WMS. I have two problems, so any help would be greatly appreciated. I've attached my mapfile definition at the bottom of the e-mail.
1. I have defined a scalebar, which I'd like to embed in the map. This works fine however, I want to place some text (a copyright notice) next to the scalebar (i.e. along the bottom of the map). To do this I think I need to include a label entry in my scalebar definition, but I can't work out how to set the text I want to display.
2. I have a vector layer which contains 136 polygons (name: 'boarders'). I'd like to make these semi-transparent, so you can still see the raster data in the layer below. Can you do this with Mapserver?
I'm using Mapserver 3.5 on Windows 2000.
Thanks in advance,
Andrew
Map file follows:
NAME EMS
STATUS ON
SIZE 500 350
EXTENT 380000 400000 450000 450000
UNITS METERS
IMAGETYPE gif
PROJECTION
"init=epsg:27700"
END
WEB
METADATA
"wms_title" "Enviroport Map Server"
"wms_onlineresource" "http://plasma/cgi-bin/mapserv.exe?map=c:\demo.map"
"wms_srs" "epsg:27700"
END
END
# Definitions for map symbols
SYMBOL
NAME 'circle'
TYPE ELLIPSE
POINTS 1 1 END
FILLED TRUE
END
# End of map symbol definitions
# Start of Map Layers, The first layer in this list is displayed at the bottom, etc.
# Raster Data - Using shapefile index
LAYER
NAME "rst50k"
TYPE raster
STATUS ON
TRANSFORM true
TILEINDEX "H:\data\50k\tiff\poly"
PROJECTION
"init=epsg:27700"
END
METADATA
WMS_TITLE "1:50,000 Colour Raster"
WMS_ABSTRACT "Add info here"
WMS_SRS "EPSG:27700"
END # End of Metadata tag
END # End of 50k raster
# Ward Data - shapefile
LAYER
NAME "boarders"
TYPE polygon
DATA "H:\data\UKBoarders\947"
STATUS OFF
TRANSFORM true
PROJECTION
"init=epsg:27700"
END
CLASSITEM "Name"
CLASS
EXPRESSION 'Bolton'
TEMPLATE "somepage.html"
OUTLINECOLOR 0 0 0
COLOR 0 255 0
END # End of class Bolton
CLASS
EXPRESSION 'Birkby'
OUTLINECOLOR 0 0 0
COLOR 255 0 0
CLASS
EXPRESSION /./
OUTLINECOLOR 0 0 0
COLOR 190 253 190
END
TOLERANCE 3
METADATA
WMS_TITLE "Wards"
WMS_ABSTRACT "Ward boundary information."
END # End of layer
# Test POI Layer
LAYER
NAME "poi"
TYPE point
DATA "H:\data\testInfo\poi"
STATUS ON
TRANSFORM true
PROJECTION
"init=epsg:27700"
END
CLASS
SYMBOL 'circle'
SIZE 2
NAME 'Townships'
OUTLINECOLOR 100 40 40
END
METADATA
WMS_TITLE "Point of Interest Data"
WMS_ABSTRACT "Test Point of Interest Data for Muckenbrough County Council"
END # End of layer
# Test for scalebar
MAP
SCALEBAR
BACKGROUNDCOLOR 0 0 0
COLOR 255 255 255
INTERVALS 3
OUTLINECOLOR 255 0 0
POSITION lr
POSTLABELCACHE true
SIZE 500 15
STATUS embed
TRANSPARENT off
STYLE 0
UNITS meters
LABEL
COLOR 0 0 0
SIZE tiny
END # END of label
END # END of scalebar
END # End of map object
END # End of file
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020205/eb406cd5/attachment.html
