[mapserver-users] 24bit tiff and gdal
Pushkar Pradhan
pushkar at ERC.MsState.Edu
Fri Feb 8 16:05:15 EST 2002
Frank,
Thanks for confirming my doubt about disabling TIFF support:
so now my MS config. says:
Banshee[51] pushkar$ mapserv -v
MapServer version 3.5 OUTPUT=PNG OUTPUT=WBMP SUPPORTS=TTF INPUT=EPPL7
INPUT=JPEG INPUT=GDAL INPUT=SHAPEFILE
But to my horror now I am unable to read either 8 or 24 bit TIFFs, I get
the foll. error:
msDrawRaster(): Image handling error. Unrecognized or unsupported image
format
and when I try to display colored jpegs also it doesn't work:
drawJPEG(): Unable to access file. Only grayscale JPEG images are
supported.
This is my path:
Banshee[91] pushkar$ echo $LD_LIBRARY_PATH
/usr/lib:/usr/local/lib:/usr/dt/lib:/usr/openwin/lib:/usr/local/gnu/lib:/opt/SUNWspro/lib:/usr/ccs/lib:/usr/ucblib:/usr/local/netpbm/lib:/rstc/user1/erc/pushkar/gdal-1.1.5
i.e. I have given the path to the gdal dir.
Apache's error log says:
[Fri Feb 8 15:01:51 2002] [notice] SIGUSR1 received. Doing graceful
restart
[Fri Feb 8 15:01:51 2002] [notice] Apache/1.3.22 (Unix) configured --
resuming normal operations
[Fri Feb 8 15:01:51 2002] [info] Server built: Nov 14 2001 12:06:07
[Fri Feb 8 15:01:51 2002] [notice] Accept mutex: fcntl (Default: fcntl)
Am I not linking properly or something?
On Thu, 7 Feb 2002, Frank Warmerdam wrote:
> Pushkar Pradhan wrote:
> > Hi,
> > I've compiled MS 3.5 with gdal:
> > Banshee[284] pushkar$ mapserv -v
> > MapServer version 3.5 OUTPUT=PNG OUTPUT=WBMP SUPPORTS=TTF INPUT=TIFF
> > INPUT=EPPL7 INPUT=JPEG INPUT=GDAL INPUT=SHAPEFILE
> > But when I try to display 24 bit tiff I get the foll. msg.:
> > drawTIFF(): Image handling error. Only colormapped and grayscale images
> > are supported.
> > This is the info. for my tiff file
> > Banshee[293] pushkar$ identify data/24bmosaic2001mstm.tif
> > data/24bmosaic2001mstm.tif 5167x3675 DirectClass 54mb TIFF 3.6u 0:25
> > I've gdal1.1.5 and this is the info. for it:
> > Banshee[296] pushkar$ gdal-config --formats
> > gxf gtiff hfa aigrid aaigrid ceos ceos2 iso8211 sdts raw dted mem jdem
> > envisat elas fit gif jpeg png
> > I have the tfw file also: 24bmosaic2001mstm.tfw
> > **My ques. is do I have to disable TIFF support if I compile mapserver
> > with GDAL? Maybe the default behaviour of MS is to use the tiff libs. read
> > the tiff imgs. and not try to use GDAL after that?
> Pushkar,
> If you want to use GDAL for your TIFF files you need to configure and
> build MapServer without direct TIFF support or the direct TIFF support
> will get used in preference. I have been sort of intending to change
> the configure to disable TIFF support (unless explicitly requested during
> the configure) if GDAL is configured in, but haven't gotten around to it.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
PUSHKAR S. PRADHAN
Research Assistant
MISSISSIPPI STATE UNIVERSITY,
STARKVILLE, MS 39759.
Engineering Research Center
Box 9627
Mississippi State, MS 39762-9627
