[mapserver-users] New to Mapserver
Stephen Woodbridge
woodbri at swoodbridge.com
Sat Feb 9 09:15:46 EST 2002
Sathis,
If you expect to get more than a few token hits on your server for
demonstration purposes, you need to seriously consider translating the
tigerline data to shape files as you will have big performance problems
otherwise. If you ever plan to expand your data beyond one state you
will need to use shapefiles also. The Census offers a bunch of boundary
shapefiles now on its website for download, I don't think they have the
street level files. Here are two layer definitions I use in my map file
that might help, but I use shapefiles not OGR:
LAYER
NAME county
MAXSCALE 799999
TYPE POLYGON
STATUS ON
TILEINDEX "tgrindex"
DATA county
CLASS
NAME "Counties"
COLOR -1 -1 -1
OUTLINECOLOR 128 128 128
END
METADATA
"DESCRIPTION" "County"
"RESULT_FIELDS" "COUNTY STATE SSCCC"
END
HEADER "html/cty_header.html"
FOOTER "html/cty_footer.html"
TEMPLATE "html/cty.html"
TOLERANCE 3
END
LAYER
NAME streets
MAXSCALE 59999
STATUS ON
DATA minroads
TYPE LINE
LABELITEM "NAME"
CLASS
NAME "Streets"
SYMBOL "circle"
COLOR 0 0 0
SIZE 4
OVERLAYSYMBOL "circle"
OVERLAYCOLOR 255 255 255
OVERLAYSIZE 2
LABEL
ANGLE AUTO
TYPE TRUETYPE
ANTIALIAS TRUE
FONT arial-bold
MINFEATURESIZE 10
MINDISTANCE 300
POSITION UC
BUFFER 4
SIZE 8
COLOR 0 0 0
OUTLINECOLOR 255 255 204
END
END
METADATA
"DESCRIPTION" "Surface Streets"
"RESULT_FIELDS" "TLID NAME CFCC FRADDL TOADDL FRADDR TOADDR ZIPL
ZIPR RTE_NUM"
END
HEADER "html/roads_header.html"
FOOTER "html/roads_footer.html"
TEMPLATE "html/roads.html"
TOLERANCE 3
END # streets
-Steve
Sathiskumar Govindasamy wrote:
> Hi,
> Thanks for your reply. Yes I wanted to go to street level mapping in the
> coming days, but I wanted to start with atleast the US and state boundaries
> with Interstates on it now. I have downloaded the Tiger Line 2000 data for
> Illinois. I have installed OGR and I am able to see the information through
> ogrinfo. But, how to I write template file and .map file with layers ? I
> would greatly appreciate your help.
> Thanks
> Sathis
> At 11:34 PM 2/8/2002 -0500, Walt Lin wrote:
> >If you just want to draw the state outlines and labels, don't use
> >TIGER-- use files from nationalatlas.gov . If you need street level
> >data for the whole US, then tiger is the way to go. Nationalatlas
> >should have just one layer for states-- setup your .map file for just
> >one layer and off you go.
> >On Fri, Feb 08, 2002 at 05:18:22PM -0600, Sathiskumar Govindasamy wrote:
> > > Hello,
> > > I am new to Mapserver. I don't know where to start. I tried to go
> > > through tutorial I couldn't get much out of it. I wanted the mapserver
> > > to generate map of US with states marked. I was told to use Tiger Line
> > > data. I don't loaded tigerline files for Illinois and also boundary line
> > > shapefiles for all the state states. Can someone tell me how to start or
> > > point me to some site where they have explained how to use Tiger data ?
> > > Thanks
> > > Sathis
