[mapserver-users] Solaris SPARC segfault (FWD)
teb
teb at mallit.fr.umn.edu
Mon Feb 11 11:41:34 EST 2002
------------- Begin Forwarded Message -------------
MIME-Version: 1.0
Date: Sun, 10 Feb 2002 14:52:08 +0100
To: gdal-dev at yahoogroups.com
Cc: mapserver-info at lists.gis.umn.edu
Subject: Solaris SPARC segfault
Hello all,
I'm trying to run mapserver's PHP/mapscript 3.5 release under solaris
sparc (on a blade 100 running the latest solaris release).
Sor far i've got everything to compile using GNU tools.
GDAL 1.1.5 and CVS compile only when using every internal libs version.
The problem is that when i try to use the mapscript php module i get a
segmentation fault.
Here's the back trace that gdb gave me :
Program received signal SIGSEGV, Segmentation fault.
0xff1b27f0 in _longjmp ()
(gdb) where
#0 0xff1b27f0 in _longjmp ()
#1 0xfe9f3608 in ?? ()
from
/usr/local/lib/php/extensions/no-debug-non-zts-20001222/php_mapscript.so
#2 0xfe7596d0 in ?? () from /usr/local/gdal/lib/libgdal.1.1.so
#3 0xfe76b0f0 in ?? () from /usr/local/gdal/lib/libgdal.1.1.so
#4 0xfe9f3f90 in ?? ()
from
#5 0xfe9f3ed8 in ?? ()
from
#6 0xfe9d94f0 in ?? ()
from
#7 0xfe9b7798 in ?? ()
from
#8 0xfec33fc4 in execute ()
#9 0xfec3430c in execute ()
#10 0xfec3430c in execute ()
#11 0xfec45808 in zend_execute_scripts (type=8, file_count=3) at
zend.c:752
#12 0xfec5b42c in php_execute_script (primary_file=0xffbef578) at
main.c:1206
That doesn't help me much...
Is there a way to have more information on where the probleme resides?
The php code used try to load PNG images...
Thanks in advance
Gilles CHERIX
Genug gewartet? sunrise ADSL: schneller im Internet.
http://www.sunrise.ch/de/internet/int_ads.asp
Assez attendu? Avec sunrise ADSL, surfez encore plus vite sur le net.
http://www.sunrise.ch/fr/internet/int_ads.asp
Stufo di aspettare? Con sunrise ADSL più veloce che mai in Internet.
http://www.sunrise.ch/it/internet/int_ads.asp
------------- End Forwarded Message -------------
