[mapserver-users] php install. problem
Jim Burnett
jimburnett at ntelos.net
Mon Feb 18 13:11:22 EST 2002
make sure you compile php as an apache module, or that the module is in the
correct path for the apache modules.
-jim
----- Original Message -----
To: "Pushkar Pradhan" <pushkar at ERC.MsState.Edu>
Cc: <mapserver-users at lists.gis.umn.edu>
Sent: Monday, February 18, 2002 1:01 PM
Subject: Re: [mapserver-users] php install. problem
> On Sun, Feb 17, 2002 at 02:18:18PM -0600, Pushkar Pradhan wrote:
> > During php install. it copies the libphp4.so to the libexec dir. of
> > apache.
> Then PHP compiles fine, am i wrong? (can you execute php console
> applications?)
> > I've added the foll. lines to httpd.conf as suggested:
> > LoadModule php4_module libexec/libphp4.so
> > AddModule php4_module mod_php4.c
> > When I try to start apache I get the foll:
> > Banshee[96] pushkar$ apachectl start
> > Syntax error on line 206 of
> > /rstc/user1/erc/pushkar/apache_1.3.22/conf/httpd.conf:
> > Cannot add module via name 'php4_module': not in list of loaded modules
> > ./apachectl start: httpd could not be started
> > If anyone has experience with this please help. Thanks,
> Has Solaris a ldconfig equivalent?, it seems that apache can't find the
> module, is in the right libexec directory? :-)
> Good luck,
> V. <v at w.cl>
