[mapserver-users] php install. problem
Pushkar Pradhan
pushkar at ERC.MsState.Edu
Mon Feb 18 14:38:22 EST 2002
My sincere thanks to all who contributed,
Inspite of asking a non MS related ques. I got responses.
Actually the first time things may go wrong but then you have to do a
'make clean' in both apache and php and then compile them.
I got this from o'reilly's website by Darrell Brogdon (author of PHP Admin
Basics).
Thought this might be useful for others so posting it.
On Mon, 18 Feb 2002, Jim Burnett wrote:
> make sure you compile php as an apache module, or that the module is in the
> correct path for the apache modules.
> -jim
> ----- Original Message -----
> From: "Vinko Vrsalovic" <v at w.cl>
> To: "Pushkar Pradhan" <pushkar at ERC.MsState.Edu>
> Cc: <mapserver-users at lists.gis.umn.edu>
> Sent: Monday, February 18, 2002 1:01 PM
> Subject: Re: [mapserver-users] php install. problem
> > On Sun, Feb 17, 2002 at 02:18:18PM -0600, Pushkar Pradhan wrote:
> > > During php install. it copies the libphp4.so to the libexec dir. of
> > > apache.
> > Then PHP compiles fine, am i wrong? (can you execute php console
> > applications?)
> > > I've added the foll. lines to httpd.conf as suggested:
> > > LoadModule php4_module libexec/libphp4.so
> > > AddModule php4_module mod_php4.c
> > > When I try to start apache I get the foll:
> > > Banshee[96] pushkar$ apachectl start
> > > Syntax error on line 206 of
> > > /rstc/user1/erc/pushkar/apache_1.3.22/conf/httpd.conf:
> > > Cannot add module via name 'php4_module': not in list of loaded modules
> > > ./apachectl start: httpd could not be started
> > > If anyone has experience with this please help. Thanks,
> > Has Solaris a ldconfig equivalent?, it seems that apache can't find the
> > module, is in the right libexec directory? :-)
> > Good luck,
> > V. <v at w.cl>
PUSHKAR S. PRADHAN
Research Assistant
MISSISSIPPI STATE UNIVERSITY,
STARKVILLE, MS 39759.
Engineering Research Center
Box 9627
Mississippi State, MS 39762-9627
