[mapserver-users] problems with raster, ecw and gdal support
Pushkar Pradhan
pushkar at ERC.MsState.Edu
Fri Mar 1 12:11:08 EST 2002
I think this is happening because when you try to load a jpeg img. the
inbuilt jpeg libs. try to draw the img. before gdal and since they can't
handle color jpegs it fails.
Try compiling mapserver --without-jpeg and --with-gdal support.
> I am having problems using raster data within mapserver using gdal. The
> mapserver i use are the ms351gif_gdal_wmsc_nightly but I tried others with
> gdal support as well.
> I get a "Content-type: text/html msDrawRaster(): Image handling error.
> Unrecognized or unsupported image format" when using ECW data and
> "drawJPEG(): Image handling error. JPEG support is not available." using
> JPEG. GIF data work fine.
> regards
> Bo Overgaard
> Carl Bro
> www.carlbro.dk
> boo at carlbro.dk
> mapserv.exe -v give the result:
> MapServer version 3.5.1 (development) OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
> INPUT=SHAPEFILE
> the map file look like this:
> NAME Kort
> STATUS ON
> SIZE 800 525
> FONTSET fonts/fontset.txt
> EXTENT 512855 6172280 666851 6297601
> UNITS METERS
> SHAPEPATH "d:/www/boo/vsa-n-m/shp"
> IMAGETYPE GIF
> WEB
> TEMPLATE dkplan.html
> MINSCALE 500
> MAXSCALE 240000000
> IMAGEPATH "d:/www/boo/vsa-n-m/tmp/"
> LOG "d:/www/boo/vsa-n-m/mapserv.log"
> END
> PROJECTION
> "proj=utm"
> "ellps=WGS84"
> "zone=32"
> "north"
> "no_defs"
> END
> LAYER
> NAME kms_raster
> TYPE RASTER
> STATUS ON
> PROJECTION
> "proj=utm"
> "ellps=WGS84"
> "zone=32"
> "north"
> "no_defs"
> END
> END
> LAYER
> NAME xgif
> DATA "kms_raster.gif"
> TYPE RASTER
> STATUS ON
> END
> LAYER
> NAME xecw
> TYPE RASTER
> STATUS ON
> DATA "Sample_15cm.ecw"
> END
> END
PUSHKAR S. PRADHAN
Research Assistant
MISSISSIPPI STATE UNIVERSITY,
STARKVILLE, MS 39759.
Engineering Research Center
Box 9627
Mississippi State, MS 39762-9627
