[mapserver-users] problems with raster, ecw and gdal support
Bo Overgaard
boo at carlbro.dk
Fri Mar 1 11:35:56 EST 2002
Tanks Steve
Actually it is the ecw support I am interested in, the information on JPEG
and GIF was only to report about the mapserver behaviour with other raster
layers. So any suggestions on how I get the ecw part working.
Bo Overgaard
Carl Bro
www.carlbro.dk
boo at carlbro.dk
-----Original Message-----
From: Steve Lime [mailto:steve.lime at dnr.state.mn.us]
Sent: Friday, March 01, 2002 4:57 PM
To: boo at carlbro.dk
Subject: Re: [mapserver-users] problems with raster, ecw and gdal
support
On the JPEG side you're MapServer wasn't compiled with JPEG support. GD
with JPEG
gives you JPEG output capability but not input capability. Libjpeg
directly for that
support (note only greyscale JPEG is supported for input). Checkout the
--with-jpeg
option of configure.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> Bo Overgaard <boo at carlbro.dk> 03/01/02 08:02AM >>>
I am having problems using raster data within mapserver using gdal.
The
mapserver i use are the ms351gif_gdal_wmsc_nightly but I tried others
with
gdal support as well.
I get a "Content-type: text/html msDrawRaster(): Image handling error.
Unrecognized or unsupported image format" when using ECW data and
"drawJPEG(): Image handling error. JPEG support is not available."
using
JPEG. GIF data work fine.
regards
Bo Overgaard
Carl Bro
www.carlbro.dk
boo at carlbro.dk
mapserv.exe -v give the result:
MapServer version 3.5.1 (development) OUTPUT=GIF OUTPUT=PNG
OUTPUT=JPEG
OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR
INPUT=GDAL
INPUT=SHAPEFILE
the map file look like this:
NAME Kort
STATUS ON
SIZE 800 525
FONTSET fonts/fontset.txt
EXTENT 512855 6172280 666851 6297601
UNITS METERS
SHAPEPATH "d:/www/boo/vsa-n-m/shp"
IMAGETYPE GIF
WEB
TEMPLATE dkplan.html
MINSCALE 500
MAXSCALE 240000000
IMAGEPATH "d:/www/boo/vsa-n-m/tmp/"
LOG "d:/www/boo/vsa-n-m/mapserv.log"
END
PROJECTION
"proj=utm"
"ellps=WGS84"
"zone=32"
"north"
"no_defs"
END
LAYER
NAME kms_raster
TYPE RASTER
STATUS ON
PROJECTION
"proj=utm"
"ellps=WGS84"
"zone=32"
"north"
"no_defs"
END
END
LAYER
NAME xgif
DATA "kms_raster.gif"
TYPE RASTER
STATUS ON
END
LAYER
NAME xecw
TYPE RASTER
STATUS ON
DATA "Sample_15cm.ecw"
END
END
