[mapserver-users] problems with raster, ecw and gdal support
Bo Overgaard
boo at carlbro.dk
Fri Mar 1 09:02:58 EST 2002
I am having problems using raster data within mapserver using gdal. The
mapserver i use are the ms351gif_gdal_wmsc_nightly but I tried others with
gdal support as well.
I get a "Content-type: text/html msDrawRaster(): Image handling error.
Unrecognized or unsupported image format" when using ECW data and
"drawJPEG(): Image handling error. JPEG support is not available." using
JPEG. GIF data work fine.
regards
Bo Overgaard
Carl Bro
www.carlbro.dk
boo at carlbro.dk
mapserv.exe -v give the result:
MapServer version 3.5.1 (development) OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
the map file look like this:
NAME Kort
STATUS ON
SIZE 800 525
FONTSET fonts/fontset.txt
EXTENT 512855 6172280 666851 6297601
UNITS METERS
SHAPEPATH "d:/www/boo/vsa-n-m/shp"
IMAGETYPE GIF
WEB
TEMPLATE dkplan.html
MINSCALE 500
MAXSCALE 240000000
IMAGEPATH "d:/www/boo/vsa-n-m/tmp/"
LOG "d:/www/boo/vsa-n-m/mapserv.log"
END
PROJECTION
"proj=utm"
"ellps=WGS84"
"zone=32"
"north"
"no_defs"
END
LAYER
NAME kms_raster
TYPE RASTER
STATUS ON
PROJECTION
"proj=utm"
"ellps=WGS84"
"zone=32"
"north"
"no_defs"
END
END
LAYER
NAME xgif
DATA "kms_raster.gif"
TYPE RASTER
STATUS ON
END
LAYER
NAME xecw
TYPE RASTER
STATUS ON
DATA "Sample_15cm.ecw"
END
END
