[mapserver-users] Create Dynamic Pt Layer, then queryByPoint()
E Perik
erwin at perik.nu
Sun Mar 3 08:14:47 EST 2002
Hi Dan,
Could you not create a new-shapefile of your points and then add this
'name' in the Map-layer. Then add the new-shapefile to the map through a
dummy-layer.
I used similar to retrieve a shape-object from an existing shapefile and
then:
1) Get shapeobject from existing-shapefile (through its index)
2) Put it in new-shapefile
3) Create dbf-file with name of new-shapefile
4) Clear new-shapefile
5) Add new-layer to map-object (default of this layer is set to OFF)
6) Show new-layer
7) Draw the map (now includes newly created shapefile ;-) )
In part 1) yours would differ. Her you create the shape-object (points)
from the SQL-database. Part 3) is needed, because mapscript does not
make a dbf-file.
Erwin
-----Original Message-----
[mailto:owner-mapserver-users at lists.gis.umn.edu] On Behalf Of Dan Barron
Sent: Friday, March 01, 2002 11:59 PM
To: Stephen Woodbridge
Cc: mapserver-users at lists.gis.umn.edu
Subject: Re: [mapserver-users] Create Dynamic Pt Layer, then
queryByPoint()
>At 05:33 PM 3/1/2002 -0500, Stephen Woodbridge wrote:
>The LAYER must have TEMPLATE defined or it will NOT be queried so make
>sure you have that set.
>-Steve
Thanks for the reply Steve. Query still does not find any points. I
have
modified my map file per your suggestion, see below. Is there some
special
way I need to create the layer? Or does the template need to call out
anything specific or could is just print "Hello world" if you wanted? I
have also included my php code that queries the database and builds the
layer.
Dan
<< map file snip >>
LAYER
NAME 'point-test'
TYPE POINT
STATUS OFF
CLASS
name 'point-test'
SYMBOL 'c:\bin\mapserver\mapservertest\graphics\novice-icon.png'
# template 'point-test-template.html'
END
template "point-test-template.html"
tolerance 10
END
<< php file snip >>
// Connect to mySQL database, print a successful or unsuccessful
message, then
// select the database to use.
$link = mysql_connect($host, $user, $pwd) or die("Could not connect");
print "Connected to mysql successfully<br>";
mysql_select_db($dbase) or die("Could not select database");
// Set query strings, then perform query
$query_select = "SELECT * FROM ".$table;
$query_where[0] = " WHERE latitude < ".$map->extent->maxy;
$query_where[1] = " AND latitude > ".$map->extent->miny;
$query_where[2] = " AND longitude < ".$map->extent->maxx;
$query_where[3] = " AND longitude > ".$map->extent->minx;
$result =
mysql_query($query_select.$query_where[0].$query_where[1].$query_where[2
].$query_where[3])
or die("Query failed");
// Loop through result of point query and:
// 1) create pointObj's to hold results of mySQL query
// 2) create lineObj's made of pointObj's values - use these for
shapeObj's
// 3) create shape objects to hold additional fields, specifically
siteid
// 4) draw the point and shape object on the map and layer
$factor = 0.5;
while ($line = mysql_fetch_array($result, MYSQL_ASSOC)) {
// create point objects
$pt = ms_newPointObj();
$pt->setXY( $line["longitude"], $line["latitude"] );
// create line objects
$ln[0] = ms_newLineObj();
$ln[1] = ms_newLineObj();
$ln[2] = ms_newLineObj();
$ln[3] = ms_newLineObj();
$ln[0]->addXY( ($pt->x - $factor), ($pt->y - $factor)
$ln[0]->addXY( ($pt->x + $factor), ($pt->y - $factor)
$ln[1]->addXY( ($pt->x + $factor), ($pt->y - $factor)
$ln[1]->addXY( ($pt->x + $factor), ($pt->y + $factor)
$ln[2]->addXY( ($pt->x + $factor), ($pt->y + $factor)
$ln[2]->addXY( ($pt->x - $factor), ($pt->y + $factor)
$ln[3]->addXY( ($pt->x - $factor), ($pt->y + $factor)
$ln[3]->addXY( ($pt->x - $factor), ($pt->y - $factor)
// create shape objects
$shp = ms_newShapeObj(MS_SHAPE_POLYGON);
$shp->add( $ln[0] );
$shp->add( $ln[1] );
$shp->add( $ln[2] );
$shp->add( $ln[3] );
$shp->set('text', $line['siteid']);
// draw objects on layers
$shp->draw($map, $shape_layer, $image, 0, "SHAEP");
$pt->draw($map, $pt_layer, $image, 0, "TEST");
// Closing connection
mysql_close($link);
