[mapserver-users] problem with join
Richard Greenwood
Rich at GreenwoodMap.com
Mon Mar 4 23:53:54 EST 2002
You can create a join in your map file. Here's an example:
Class
Join
from PIDN
name jointest
table "\Tc\DATA\assessor.DBF"
# TEMPLATE join_region.shp_query.html # required only for
one-to-many joins
to Pidn
type single
End # of Join Object
SYMBOL "Solid"
OUTLINECOLOR 0 0 0
END # of Class
This is pretty well documented. Be careful how much editing is done to the
dbf - adding or deleting records will break the join.
Also note that you can only use a join for queries, not labeling. If you
need to label features off the dbf you are out of luck. You will need to
create the join in ArcView or MapInfo, and save it out as a single, static
layer.
Rich
At 11:54 AM 3/4/2002 +0100, you wrote:
>hi,
>my (little) problem:
>i have a shape and i have ab big dbf-file.
>the polys in the shape have 1 (one!) item - the ID , all other dates are
>in the dbf (landuse, name, number, ........)
>i want to join both files to shade the poly in different views (first
>landuse, later name, ....)
>my users should only edit in the dbf-file!
>and now my problem: how must I join to shade different with datas from the
>joined dbf???
>who has an example for me (map-file?)
>great thanks.
>mikeE.:-)
Richard W. Greenwood, PLS
Greenwood Mapping, Inc.
(307) 733-0203
http://www.GreenwoodMap.com
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020304/283aebe8/attachment.html
