[mapserver-users] Big Square, Tiny Map
Fawcett, David
david.fawcett at moea.state.mn.us
Wed Mar 6 12:41:51 EST 2002
Jim,
It looks like your extent is in decimal degrees. Is your data also in decimal degrees? Are your units still set to Meters?
It could be that you need to make all of these consistent.
The Itasca demo uses data in UTM, with meters as the units.
David.
David J. Fawcett
GIS / Databases
MN Office of Environmental Assistance
520 Lafayette Rd N
St. Paul, MN 55155
651.215.0200
> From: Jim Palma[SMTP:jpalma at donahue.umassp.edu]
> Sent: Wednesday, March 06, 2002 11:13 AM
> To: MapServer
> Subject: [mapserver-users] Big Square, Tiny Map
> OK, now that I know that the error is only near the line number, it
> turned out to be the lack of map extent information. I used this as the
> extent for Massachusetts:
> minx: -73.652156
> miny: 42.924232
> maxx: -69.787764
> maxy: 41.206216
> Now I have a new problem, and maybe it is related to the input I used
> above. My map is a tiny dot in the middle of the display square. I
> can't zoom in on it. Something is wrong with my settings, but I can't
> figure it out. Take a look:
> http://maps.donahue.umassp.edu/massachusetts/massachusetts_init.html
> Would the wrong extent information do this? Is it a projection problem
> (the files are in latitude/longitude, but I could change that). Is it a
> settings problem in the .map file? Or what?
> Thanks for any help you can give a rank newbie.
> Jim
