[mapserver-users] Big Square, Tiny Map
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Mar 6 12:41:38 EST 2002
Jim,
You probably need to change the html now to reflect what layers you
really have in the map file. Also you can change all the STATUS
ON/OFF/DEFAULT to DEFAULT to force them to show up.
-Steve
Jim Palma wrote:
> OK, now that I know that the error is only near the line number, it
> turned out to be the lack of map extent information. I used this as the
> extent for Massachusetts:
> minx: -73.652156
> miny: 42.924232
> maxx: -69.787764
> maxy: 41.206216
> Now I have a new problem, and maybe it is related to the input I used
> above. My map is a tiny dot in the middle of the display square. I
> can't zoom in on it. Something is wrong with my settings, but I can't
> figure it out. Take a look:
> http://maps.donahue.umassp.edu/massachusetts/massachusetts_init.html
> Would the wrong extent information do this? Is it a projection problem
> (the files are in latitude/longitude, but I could change that). Is it a
> settings problem in the .map file? Or what?
> Thanks for any help you can give a rank newbie.
> Jim
