Found the Problem (Re: [mapserver-users] Is PostGIS broken in latest nightly build on Win32?)
    Pericles S. Nacionales
    pnaciona at gis.umn.edu
    Tue Mar 12 11:13:41 PST 2002
Sean,
You'll probably have better luck getting answers to your question using
the PostGIS support...  http://postgis.refractions.net/support.php.
They have an FAQ and a web-based discussion group.
Good luck!
Perry
-----Original Message-----
From: owner-mapserver-users at lists [mailto:owner-mapserver-users at lists]
On Behalf Of Sean Gillies
Sent: Tuesday, March 12, 2002 12:44 PM
Cc: mapserver-users at lists
Subject: Found the Problem (Re: [mapserver-users] Is PostGIS broken in
My features are too large (in bytes). When I query with
'astext(envelope(the_geom))', the bounding boxes of the
features are returned properly.
Are geometries limited to 8k?  Will this limit be lifted
in postgresql 7.2?
Sean
Sean Gillies wrote:
> Greetings,
> Am having sucess using PostGIS (very recent CVS build) as a data
source
> with mapserver built on Linux but am unable to use this same data
source
> with the most recent ms351_nightly w/postgis.
> I am seeing this error:
> msPOSTGISLayerWhichShapes(): Query error. Error executing POSTGIS SQL
> statement (in FETCH ALL): DECLARE mycursor BINARY CURSOR FOR SELECT
State_abbr::text,asbinary(force_collection(force_2d(the_geom)),'NDR'),oi
d::text
> from dtlst WHERE the_geom && setSRID('BOX3D(-126 22.2637931034483,-65
> 51.7362068965517)'::BOX3D, find_srid('','dtlst','the_geom') )
> The win32 binary works with shapefile data, but not with a PostGIS
data
> source which works with our Linux mapserver.  The PostgreSQL server
> is on Linux and we reliably access it from many other windows
> applications.
> The software versions are:
> PostgreSQL 7.1.2
> PostGIS 0.7-ish (from CVS on March 5)
> Mapserver win32 binary w/ postgis from March 11
> Looking forward to hearing any solutions or suggestions,
> Sean
More information about the MapServer-users
