Found the Problem (Re: [mapserver-users] Is PostGIS broken in latest nightly build on Win32?)
Sean Gillies
sgillies at i3.com
Tue Mar 12 13:44:03 EST 2002
My features are too large (in bytes). When I query with
'astext(envelope(the_geom))', the bounding boxes of the
features are returned properly.
Are geometries limited to 8k? Will this limit be lifted
in postgresql 7.2?
Sean
Sean Gillies wrote:
> Greetings,
> Am having sucess using PostGIS (very recent CVS build) as a data source
> with mapserver built on Linux but am unable to use this same data source
> with the most recent ms351_nightly w/postgis.
> I am seeing this error:
> msPOSTGISLayerWhichShapes(): Query error. Error executing POSTGIS SQL
> statement (in FETCH ALL): DECLARE mycursor BINARY CURSOR FOR SELECT
> State_abbr::text,asbinary(force_collection(force_2d(the_geom)),'NDR'),oid::text
> from dtlst WHERE the_geom && setSRID('BOX3D(-126 22.2637931034483,-65
> 51.7362068965517)'::BOX3D, find_srid('','dtlst','the_geom') )
> The win32 binary works with shapefile data, but not with a PostGIS data
> source which works with our Linux mapserver. The PostgreSQL server
> is on Linux and we reliably access it from many other windows
> applications.
> The software versions are:
> PostgreSQL 7.1.2
> PostGIS 0.7-ish (from CVS on March 5)
> Mapserver win32 binary w/ postgis from March 11
> Looking forward to hearing any solutions or suggestions,
> Sean
