[mapserver-users] MS 3.5 Trouble getting a POLYLINE shape file to display
klehr1 at tampabay.rr.com
Wed Mar 13 02:28:56 EST 2002
Good morning:
I'm using Mapserver 3.5. and I have a shape file (dimension lines for a parcel layer) that appears to be of type Poly Line in ESRI Arcview GIS 3.2a (i.e. when I open it I see all lines, and when I open the .dbf it calls the fields RPOLY...see below).
The only TYPE I can get to display in Mapserv is POINT, if I try TYPE LINE, POLYLINE, or POLYGON, I get the errror: msDrawShape(): General error message. Only polygon or line shapes can be drawn using a line layer definition. (or similar error for polygon, and getSymbol(): Symbol definition error. (POLYLINE):(9) for POLYLINE). I know POLYLINE is no longer used in 3.5 but I thought I'd try it.
Map File:
NAME lines
EXTENT 2453973.98744173 213648.197153 2554427.20872896 341848.56871657
SIZE 150 150
SHAPEPATH "/maps/"
LAYER
NAME "Parcel_Grid"
DATA dim_lines
STATUS DEFAULT
TYPE POLYLINE
CLASS
OUTLINECOLOR 255 0 0
# COLOR 255 0 0
END
END
END
DBF Fields:
FNODE_, TNODE_, LPOLY_, RPOLY_, LENGTH, HISTORIC_, HISTORIC_I, CODE
Any suggestions on what how to export the data from ESRI or map file parameters I might be mis-using? I have tried combinations of TYPE POLYGON and color and outlinecolor and received the error above, and LINE and color and outlinecolor (note in each of POLYGON, LINE I tried both color and outlinecolor, and each separately).
Thanks
Steve Lehr
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020313/ed06d837/attachment.html
