[mapserver-users] MS 3.5 Trouble getting a POLYLINE shape file to
display
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Mar 13 08:28:20 EST 2002
Steve,
Use:
shpdump <shp file> | head
it will tell you on the first line what type of data is stored in the
shape file. If you want to change it's type you will probably have to
write some Perl or C code to read the shape file and write a new one,
using shplib
-Steve W.
> klehr1 at tampabay.rr.com wrote:
> Good morning:
> I'm using Mapserver 3.5. and I have a shape file (dimension lines for
> a parcel layer) that appears to be of type Poly Line in ESRI Arcview
> GIS 3.2a (i.e. when I open it I see all lines, and when I open the
> .dbf it calls the fields RPOLY...see below).
> The only TYPE I can get to display in Mapserv is POINT, if I try TYPE
> LINE, POLYLINE, or POLYGON, I get the errror: msDrawShape(): General
> error message. Only polygon or line shapes can be drawn using a line
> layer definition. (or similar error for polygon, and getSymbol():
> Symbol definition error. (POLYLINE):(9) for POLYLINE). I know
> POLYLINE is no longer used in 3.5 but I thought I'd try it.
> Map File:
> NAME lines
> EXTENT 2453973.98744173 213648.197153 2554427.20872896 341848.56871657
> SIZE 150 150
> SHAPEPATH "/maps/"
> LAYER
> NAME "Parcel_Grid"
> DATA dim_lines
> STATUS DEFAULT
> TYPE POLYLINE
> CLASS
> OUTLINECOLOR 255 0 0
> # COLOR 255 0 0
> END
> END
> END
> DBF Fields:
> FNODE_, TNODE_, LPOLY_, RPOLY_, LENGTH, HISTORIC_, HISTORIC_I, CODE
> Any suggestions on what how to export the data from ESRI or map file
> parameters I might be mis-using? I have tried combinations of TYPE
> POLYGON and color and outlinecolor and received the error above, and
> LINE and color and outlinecolor (note in each of POLYGON, LINE I tried
> both color and outlinecolor, and each separately).
> Thanks
> Steve Lehr
