again... [mapserver-users] mapext=shapes and projection on
the fly.
Steve Lime
steve.lime at dnr.state.mn.us
Thu Mar 14 13:15:47 EST 2002
Hmm... I'm assuming then that shapes aren't getting projected at some
point in the process. I've got a hunch
where but can't look at the moment. Would you please file this as a bug
at mapserver.gis.umn.edu/bugs. I'm
thinking there might be a quick fix if I'm right.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "Bullock, Martha F ERDC-CRREL-NH"
<Martha.F.Bullock at erdc.usace.army.mil> 03/07/02 11:56AM >>>
I'm having the same problem - has anyone come up with a solution yet?
Issuing mode, qlayer, (and filter) with mapext=shapes in an
application
where the layers and map are NOT projected works just as one would
expect
(the feature is highlighted and defines the mapextent).
However, specifying mode, qlayer, (and filter) and mapext=shapes with
a
PROJECTED LAYER does not work. Instead, the map zooms to the very
center of
your map at the web object MINSCALE. (as Debbie explains below).
Is this a bug or are we missing an essential parameter?
I'm sure I could work around it by hard-coding extents, but would
rather not
if someone has an alternative way around this.
Thanks so much -- Martha
-----Original Message-----
From: Debbie Pagurek [mailto:pagurekd at em.agr.ca]
Sent: Thursday, January 31, 2002 9:24 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [mapserver-users] mapext=shapes and projection on the fly
Hi all,
I have a question regarding queries:
I have a map file in which I am using the PROJECTION tag to project
on-the-fly from latlong to lcc. When I click on a polygon, I want the
query
results to zoom to this polygon and hilite it. However, when I use
mapext=shapes, the coordinates are in latlong, not the projected
coordinates
and as a result, the map is zoomed to a tiny area that is NOT where I
clicked. Is this by design or is this a bug? Is there a way to force
mapext=shapes to return values in projected coordinates? I am still
using
Mapserver CGI and haven't 'graduated' yet to mapscripting...
Mapserver 3.5 on Linux
Thanks,
D. Pagurek
