[mapserver-users] HOWTO Split Large SHP Files
Vic Kelson
vic at wittmanhydro.com
Fri Mar 15 13:54:55 EST 2002
Folks,
I wrote a Python script that splits a shapefile into pieces, using
pyshapelib. It was a snap, about 15 lines of code. I'll try to locate
the code and pass it along...
Vic.
On Fri, 2002-03-15 at 09:27, Stephen Woodbridge wrote:
Luca,
I don't think there is a general tool to do that, but if you know C it
is pretty easy to use shplib to write utility to read the shape file and
dump specific records to different files. You can also do this using
Perl and the XBase and shplib addins.
Why do you want to split the file?
performance? have you tried building a shptree index?
-Steve W.
Luca Pescatore wrote:
> Where i can find "How To Split Large SHP Files" in to small files ?
> Is it available an How To ? I can't din it on Wiki.
> Best Regards,
> Luca Pescatore
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020315/e7d6b8e8/attachment.html
