[mapserver-users] Mapinfo TAB files and lcc projection
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Mar 15 15:50:45 EST 2002
Ari,
I looked and don't think I can help with your specifiec question, but I
did notice another problem that I ran into recently. In you map file you
have:
SIZE 600 600
#EXTENT -565918.875607 55035.833974 506926.040335 1264723.213684
EXTENT -180 -90 180 90
UNITS METERS
You probably need to change to "UNITS DD".
The aspect ratio of your image 600/600 = 1 and the aspect ratio of the
map is 360/180 = 2 this will confuse mapserver for some opperations. You
should change you EXTENT -180 -180 180 180
The UNITS may be also messing up your initial zoom state,
-Steve W.
Ari Yakar wrote:
> Hi All,
> I am trying to use simple Mapinfo TAB files (Map of Canada,capitals and
> Highways) with Mapserver 3.5. If I don't
> apply any projection there is no problem. However when I specify the
> projection
> settings, map loads with 40x zoomed in. I have to Zoom out to see the whole
> map.
> I checked documentation of proj3 and proj4 but can't figure out the proper
> settings
> The following is the PROJECTION settings I have in the map file.
> PROJECTION
> "proj=lcc"
> "ellps=GRS80"
> "lat_0=60"
> "lon_0=-105"
> "lat_1=61.666666700"
> "lat_2=63.333333300"
> "datum=NAD83"
> "units=m"
> END
> I am attaching the Map file just in case it might help to identify the
> problem.
> Thanks
> Ari Yakar
> Globvision Inc.
> demo.map Type: Plain Text (text/plain)
> Encoding: quoted-printable
