[mapserver-users] RE: [Mapserver-users] HOWTO Split Large SHP Files
Hankley, Chip
Chip.Hankley at GASAI.Com
Fri Mar 15 16:37:33 EST 2002
I could be missing something on how tileindexes work (if I am, someone
please comment)... but this is how I have done this.
Where I have a large, detailed shapefile, I chunk it up into a bunch of
smaller shapefiles, then use the TILEINDEX feature in MapServer to display
the group of shapefiles.
Basically, I first create a "tile" shapefile. There are a number of ways
that you can do this... I basically convert a grid of some specified size
into a polygon shapefile and use that as my tile.
Next, I run a script in ArcView that chunks up the input shapefile based on
the individual "tiles" in the "tile" shapefile.
I've written an avenue script (below) that does this second part, so if you
have access to AV 3.x, you could do it this way.
Chip
' Name: View.CreateTiles
' Title: Creates a series of tiled shapefiles
' Topics: Views
' Description: This script will create a 'tile' of shapefiles
' from one shapefile based on an input shapefile
' that defines the tile.
' Requires: An input theme to be "tiled" and another theme
' (polygon) that defines the tile shape.
' NOTE: Derived from a cliping script developed by Pasi Hyvonen
' Self: Not Applicable
' Returns: Not Applicable
' Author: Chip Hankley - GIS Coordinator
' Graef, Anhalt, Schloemer & Associates, Inc.
' 5126 West Terrace Drive
' Madison, Wisconsin 53718-8949
' PHONE 608.245.1969 FAX 608.242.0787
' chip.hankley at gasai.com
' http://www.gasai.com
' Date: 03/15/2002'
' Get the input shapefile. This is the shapefile
' to be "tiled." It will be the active theme.
theView = av.GetActiveDoc
themesList = theView.GetThemes
theClipTheme = MsgBox.List(themesList, "Select the Theme to be TILED",
"MapServer Tiling Utility")
theClipThemeFTab = theClipTheme.GetFtab
' Get the shapefile that defines the tile shape
theTileTheme = MsgBox.List(themesList, "Select the Theme that defines the
TILE boundaries", "MapServer Tiling Utility")
theTileThemeFTab = theTileTheme.GetFtab
' Assign a uniqueID to each polygon in the tile
' shapefile
aTheme = theTileTheme
currentFtab = aTheme.GetFtab
addRecno = FALSE
hasRecno = FALSE
updateattr = FALSE
for each attr in currentFtab.GetFields
if (attr.AsString.UCase = "RECNO") then
hasRecno = TRUE
if (MsgBox.YesNo(atheme.AsString+" contains RECNO attribute."+nl+
"Do you want to update it?","Update",FALSE)) then
updateattr = TRUE
break
else
break
end
end
end
numRecs = currentFTab.GetNumRecords
if (hasRecno.Not) then
addRecno = (MsgBox.YesNo("Add Record Number Attribute "+nl+
"to "+atheme.AsString+"?","Query",TRUE))
if (addRecno) then
currentFtab.SetEditable(TRUE)
recAttr = Field.Make("Recno",#FIELD_LONG,8,0)
av.ShowMsg("Adding Recno Attribute to "+atheme.AsString+"...")
currentFtab.AddFields({recAttr})
av.ClearMsg
end
end
if ((updateattr) or (addRecno)) then
recnoField = currentFtab.FindField("Recno")
for each recNum in currentFtab
recno = ( recNum + 1 ).SetFormat("d").AsString
currentFtab.SetValue( recnoField, recNum, recno )
av.ShowMsg("Populating Recno Attribute of "+atheme.AsString+"...")
proceed = av.SetStatus((recNum / numRecs) * 100)
if ( proceed.Not ) then
av.ClearStatus
av.ShowMsg( "Stopped" )
exit
end
end
currentFtab.SetEditable(FALSE)
av.SetStatus(100)
av.ClearMsg
av.ClearStatus
end
' Set up a loop that sequentially goes through each
' "tile" in the tiling shapefile and "clips" the
' input shapefile and assigns it a unique ID.
thePath = msgbox.input("Type the path (END WITH A \) of the director to dumb
clipped shapefiles", "Specify Location", "C:\TMP\")
for each i in 1..numrecs
theTileThemeFTab.GetSelection.ClearAll
theTileThemeFTab.UpdateSelection
theBitmap = theTileThemeFTab.GetSelection
strQuery = "[Recno] = "++i.asString
test = theTileThemeFTab.Query(strQuery, theBitmap, #VTAB_SELTYPE_NEW)
theTileThemeFTab.SetSelection(theBitmap)
' def = av.GetProject.MakeFileName("LM_", "shp")
' def = FileDialog.Put(def, "*.shp", "Convert " + theTileTheme.getName)
' anFTab = theTileThemeFTab.Export(def, Shape,
theTileThemeFTab.GetSelection.Count > 0)
for each rec in theTileThemeFTab.GetSelection
theShape =
theTileThemeFTab.ReturnValue(theTileThemeFTab.FindField("shape"),rec)
end
' Select features that intersect the view extent and export the selected
ones into new shapefile.
theClipThemeFTab.SelectByShapes({theShape}, #VTAB_SELTYPE_NEW)
theFileNameString = thePath +"clip" + i.AsString
theClipThemeExport =
theClipThemeFTab.ExportClean(theFileNameString.AsFileName, TRUE)
strClass = theClipThemeFTab.GetShapeClass.GetClassName
if ((strClass = "Polygon") or (strClass = "PolyLine")) then
' Clip polygon and polyline themes
thmTemp = FTheme.Make(theClipThemeExport)
theView.AddTheme(thmTemp)
theView.SetEditableTheme(thmTemp)
if (thmTemp.GetFTab.IsEditable) then
thmTemp.GetFTab.GetSelection.SetAll
thmTemp.ClipSelected(theShape)
end
thmTemp.GetFTab.SetEditable(FALSE)
theView.SetEditableTheme(nil)
theView.DeleteTheme(thmTemp)
end
end
