[mapserver-users] tileindex
Jason Wolfe
jwolfe at sdimaps.com
Tue Mar 19 10:45:40 EST 2002
I have another question, I am trying to use a tileindex and I can not
get anything to display. I can get the individual tifs to display, but
no shapefile. Will the extents be the same for the shapefile and the
images? I used the gdaltindex command to create it, so I am assumning
it made it in the same projection of the images. Does anyone have any
suggestions?
Here is my map file:
MAP
NAME DRGVIEWER
EXTENT 477340.477 4303486.362 490383.479 4287095.437
SIZE 400 400
SHAPEPATH "../downloads/drgs/24k/clipped"
IMAGETYPE png
UNITS meters
WEB
IMAGEPATH "/var/www/html/tmp/"
IMAGEURL "/tmp/"
TEMPLATE drg.html
END
LAYER
NAME "testshape"
STATUS ON
TILEINDEX "test.shp"
TILEITEM "Location"
TYPE RASTER
END
# LAYER
# NAME drg_g1
# STATUS default
# TYPE RASTER
# DATA "o38087g2.tif"
# END
END
If I comment out the first layer and uncomment the second layer, the
image will draw up with the same extents. But this way nothing draws
up...white screen!
Jason
