[mapserver-users] Hacking Mappostgis.c to allow Views as Mapserver
Data Source
Dave Blasby
dblasby at refractions.net
Tue Mar 19 13:01:58 EST 2002
Sean,
Thanks a lot for your comments and work on the mappostgis.c
connector!
Its always great to see someone contributing!
Sean Gillies wrote:
> 1. Querying a unique row ID called "URID" instead of the Postgres
> OID.
The reason why I used OID was because it is always available in every
table, and is always unique. Relying on a column called "URID" to
exist,
be an integer, and be unique is a pretty hefty assumption. Plus it
requires people to manually add this column to every table.
As an alternative, you can check with msPOSTGISLayerGetItems() to
see if there is a "URID" column. If there is, use it, otherwise use
OID.
This way only people with a "URID" column thats non-integer or
non-unique
will have problems.
Perhaps we should call it "UNIQUE_INT_ID" so its highly unlikely someone
would
mistake what it is and what it should contain?
> (Code in mappostgis.c presumes the geometry to be the last field
> in the record, so you have to explicitly list columns in your
> view definition in order to get the proper order.)
This shouldnt be the case - I explictly query the columns in
a particular order:
SELECT name,address,dollar_value,<geometry> FROM ...
The underlying database order of columns is unimportant (you can
even have more than one geometry column in your query).
Later on, I do make the assumption about the order of the columns
begin returned by postgresql - but that assumption is justified.
> 2. The code in mappostgis.c which parses the message from EXPLAIN to
> get the query fields returns some bogus fields named "<>" from
> a view. So, I made a small change to throw out these bogus
> fields.
Excellent - I hadnt noticed the false column names postgresql produces
when looking at views. Strange - I'll definately add this patch in.
dave
