[mapserver-users] Hacking Mappostgis.c to allow Views as Mapserver
Data Source
Sean Gillies
sgillies at i3.com
Tue Mar 19 14:25:56 EST 2002
Dave,
Thanks for the response.
Perhaps the answer to the OID issue is to allow a user to
specify an optional alternative to OID in the Mapserver
DATA parameter like
"the_geom from view USING UNIQUE ID urid"
If there is no ' USING UNIQUE ID *' string, meaning
strstr(layer->data, " USING UNIQUE ID") == NULL)
you could default to the OID?
This was suggested to me by David Graham.
At this moment I am writing a function that will parse the
layer->data into geom_column_name, table_name and urid_name
using the 'using unique id' keywords. I'd like to contribute
it the the code if you think it would be useful.
One more thing -- I am having problems with sub-selects here
with my win32 mapserver. A DATA parameter like:
"the_geom from (select oid,* from table) as foo"
is failing because the Mapserver goes to the geometry_columns
table (using find_srid()) looking for an f_table_name of
'(select oid,* from table) as foo'. Have I uncovered a win32-
specific bug?
cheers,
Sean
Dave Blasby wrote:
> Sean,
> Thanks a lot for your comments and work on the mappostgis.c
> connector!
> Its always great to see someone contributing!
> Sean Gillies wrote:
>>1. Querying a unique row ID called "URID" instead of the Postgres
>> OID.
> The reason why I used OID was because it is always available in every
> table, and is always unique. Relying on a column called "URID" to
> exist,
> be an integer, and be unique is a pretty hefty assumption. Plus it
> requires people to manually add this column to every table.
> As an alternative, you can check with msPOSTGISLayerGetItems() to
> see if there is a "URID" column. If there is, use it, otherwise use
> OID.
> This way only people with a "URID" column thats non-integer or
> non-unique
> will have problems.
> Perhaps we should call it "UNIQUE_INT_ID" so its highly unlikely someone
> would
> mistake what it is and what it should contain?
[snip]
> dave
