[mapserver-users] user map from mysql table: Have a look at my code.
Can`t add layer with user data to map
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Mar 19 13:25:22 EST 2002
Jan,
I'm not sure about this, but I think you need to close the DBF and SHP
files that you create before you ask mapserver to display them.
Also this is not a good way to do this, because if you get two hits
close together the second hit will open the same file and try to write
data in it which my invalidate the file for the first hit.
You should look at the posts that came in today and yesterday? Subject
"Drawing features dynamically" which describes doing exactly what you
are trying to do.
-Steve W.
Jan Mantkowski wrote:
> Hi all,
> i run into a problem i can not solve by myself.
> I like to display names (at the right locations) of users as an additional
> layer to an existing map.
> I use:
> Windows 98
> Apache (newest)
> Mapserver 3.5
> PHP/mapscript
> php 4.0.6
> mysql(newest)
> The following parts work right now:
> get test data from mysql table
> display test data on screen for check
> make users.dbf, users.shp, users.shx
> display map on screen
> The problem is, that the user names will NOT be displayed at the map.
> Please help.
> I am using the first simple europe map and code from the example at
> http://mapserver.gis.umn.edu/doc/phpmapscript-byexample-howto.html
> This is the test data stored in a mysql table:
> 51.5063 -0.1271 Jan London
> 40.4203 -3.7057 Jose Madrid
> 48.8547 2.3453 Madeleine Paris
> 53.5548 9.9898 Fritz Hamburg
> The last name gives a hint, where the user should be displayed.
> I will post two files: europe.map and index.php please have a look at them:
> This is the map file i use. Its the original map file from the europe
> example. I only added the Layer PostNukeUsers.
> (I grabbed the state park layer from the tutorial3.5, example4.map file and
> changed STATUS to ON, also i deleted the SYMBOLSCALE 250000 line)
> I do not "really" understand what i did, so bear with me.
> NAME FIRSTMAP
> SIZE 400 400
> STATUS ON
> EXTENT -5696501 1923039 5696501 11022882
> UNITS METERS
> SHAPEPATH "data"
> WEB
> IMAGEPATH "c:\Apache\htdocs\tmp\"
> IMAGEURL "/tmp/"
> END
> LAYER
> NAME world
> TYPE POLYGON
> STATUS ON
> DATA europa
> CLASS
> TEMPLATE void
> COLOR 110 50 100
> OUTLINECOLOR 200 200 200
> #END
> END
> TOLERANCE 10
> END
> LAYER
> NAME "Nations"
> DATA europa
> STATUS ON
> TYPE ANNOTATION
> CLASS
> COLOR -1 -1 -1 # no marker will be drawn
> LABEL
> SIZE MEDIUM
> COLOR 132 31 31
> OUTLINECOLOR 255 255 255
> BUFFER 4
> END
> END
> END
> END
> LAYER
> NAME "PostNukeUsers"
> DATA users
> STATUS ON
> TYPE ANNOTATION
> LABELITEM "text"
> CLASS
> LABEL
> SIZE MEDIUM
> COLOR 132 31 31
> BUFFER 4
> END
> END
> END
> END
> This is the index-standalone.php file, that does all the work:
> <?php
> // load .dll`s, this makes sure that you do not need to edit the php.ini.
> dl("php_mapscript_35.dll");
> dl("php_proj.dll");
> dl("php_dbase.dll");
> // start preparation files
> $shpPath = "c:/Apache/htdocs/pn_71/html/modules/map/data/"; // Do not forget
> the / in the end of the line!
> $shpFileName ="users";
> $shpFname = $shpPath.$shpFileName;
> $shpFile = ms_newShapeFileObj($shpFname, MS_SHP_POINT);
> $def =
> array(
> array("name", "C", 20), // in the map.dbf there is no need for lat and lon
> $dbfFile = dbase_create( $shpFname.".dbf", $def);
> // end preparation files
> // lets do it
> $db = mysql_connect("localhost", "root", "");
> mysql_select_db("Rogue",$db);
> $result = mysql_query("SELECT * FROM nuke_map",$db);
> if ($result === false) die("failed");
> echo " This is the test data from the mysql table that should be displayed.
> The last name gives a hint, where the user should be displayed.";
> echo "<br>";
> echo "<br>";
> echo
> "lat
> lon n
> ame<br>\n";
> while ($fields = mysql_fetch_row($result)) {
> $name=$fields[0]; //i know that there are 3 columns in the mysql
> table
> $lat=$fields[1];
> $lon=$fields[2];
> out($lat, $lon, $name); //prints data from mysql table on screen for
> check
> createPoint($lat, $lon, $name); //creates map.dbf, map.shp, map.shx
> display_map(); //displays a map of europe, this is where
> the users will be displayed
> //end
> function display_map (){
> $map_path="/data/";
> $map = ms_newMapObj($map_path."europe.map");
> $image=$map->draw();
> $image_url=$image->saveWebImage(MS_PNG,1,1,0);
> echo "<img src=\"".$image_url."\">";
> function out($lat, $lon, $name){
> echo
> $lat." ".$lon." ".$name."<br>\
> n";
> function createPoint($lat, $lon, $name){
> GLOBAL $shpFile, $dbfFile;
> // Create shape
> $oShp = ms_newShapeObj(MS_SHP_POINT);
> $oLine = ms_newLineObj();
> $oLine->addXY($lat, $lon);
> $oShp->add( $oLine );
> $shpFile->addShape($oShp);
> // Write attribute record
> dbase_add_record($dbfFile, array($name));
> // clean up
> $shpFile->free();
> #dbase_close($dbfFile);
> //$result->close(); // this line is deaktivated, because it causes this
> error:
> //Fatal error: Call to a member function on a non-object in ....
> //$db->close(); // this line is deaktivated, because it causes this error:
> //Fatal error: Call to a member function on a non-object in....
> // Any help is apereciated to fix this.
> // I believe it is because of changes from php3.0 to 4.0, but i know nothing
> about classes and methods, so i can not fix it by my own.
> Thank for your help.
> Jan
