[mapserver-users] FILTER on 2 or more items
Stepan Kafka
stepan.kafka at centrum.cz
Wed Mar 20 07:42:40 EST 2002
You can use this syntax in the map file:
FILTER ("[ST_NAME]" = "%state%" and "[POLY_TYPE]" = "S")
in this case you need only submit "state" parameter from your form.
You can pass also use whole expression via "map_stmap_filter" parameter,
e.g.:
..&map_stmap_filter=("[ST_NAME]"="NY" and "POLY_TYPE" ="S")&...
> -----Pùvodní zpráva-----
> Od: owner-mapserver-users at lists.gis.umn.edu
> [mailto:owner-mapserver-users at lists.gis.umn.edu]za uivatele Bullock,
> Martha F ERDC-CRREL-NH
> Odesláno: 19. bøezna 2002 16:00
> Komu: 'mapserver-users at lists.gis.umn.edu'
> Pøedmìt: [mapserver-users] FILTER on 2 or more items
> Dear MapServer List:
> I would like to filter an itemnquery with an expression involving
> 2 or more
> items.
> I can filter on one item - the FILTERITEM - by sending MapServer a regular
> expression of the value(s) (i.e. ST_NAME = NY).
> However, I can't seem to get the syntax correct to send it an expression
> involving 2 or more items (i.e. ST_NAME = NY and POLY_TYPE = S).
> When I try to build an expression (see examples in lines 3-5 below), my
> search "... returned no results. No matching record(s) found."
> Does anyone have any hints as to how I should format my equation to
> correctly filter and display the layer?
> Thanks! martha
> Potential Equations:
> (Line 2) works, but lines 3)-5) don't)
> 1) selstate = document.mapserv.stater.value; // stater = text box to
> enter state name
> 2) stexp = "/" + selstate + "/"; // ** WORKS
> 3) // stexp = "ST_NAME = /" + selstate + "/ and POLY_TYPE = /S/"; //
> ** test
> 4) // stexp = "'ST_NAME' = /" + selstate + "/ and 'POLY_TYPE' =
> /S/" //
> ** test
> 5) // stexp = "[ST_NAME] = /" + selstate + "/ and [POLY_TYPE] =
> /S/" //
> ** test
> 6) document.mapserv.map_stmap_filter.value = stexp;
> Map file layer definition:
> LAYER
> NAME stmap
> DATA data/usstates
> TYPE polygon
> STATUS default
> FILTERITEM ST_NAME
> # FILTER "%stater%"
> TEMPLATE querytest.html
> CLASSITEM "ST"
> CLASS # red
> EXPRESSION /53|11|12|15|19|20|26|28|33|34|38|44|49|54|60/
> SYMBOL 0
> COLOR 255 153 153
> END
