[mapserver-users] FILTER on 2 or more items
Bullock, Martha F ERDC-CRREL-NH
Martha.F.Bullock at erdc.usace.army.mil
Tue Mar 19 10:00:25 EST 2002
Dear MapServer List:
I would like to filter an itemnquery with an expression involving 2 or more
items.
I can filter on one item - the FILTERITEM - by sending MapServer a regular
expression of the value(s) (i.e. ST_NAME = NY).
However, I can't seem to get the syntax correct to send it an expression
involving 2 or more items (i.e. ST_NAME = NY and POLY_TYPE = S).
When I try to build an expression (see examples in lines 3-5 below), my
search "... returned no results. No matching record(s) found."
Does anyone have any hints as to how I should format my equation to
correctly filter and display the layer?
Thanks! martha
Potential Equations:
(Line 2) works, but lines 3)-5) don't)
1) selstate = document.mapserv.stater.value; // stater = text box to
enter state name
2) stexp = "/" + selstate + "/"; // ** WORKS
3) // stexp = "ST_NAME = /" + selstate + "/ and POLY_TYPE = /S/"; //
** test
4) // stexp = "'ST_NAME' = /" + selstate + "/ and 'POLY_TYPE' = /S/" //
** test
5) // stexp = "[ST_NAME] = /" + selstate + "/ and [POLY_TYPE] = /S/" //
** test
6) document.mapserv.map_stmap_filter.value = stexp;
Map file layer definition:
LAYER
NAME stmap
DATA data/usstates
TYPE polygon
STATUS default
FILTERITEM ST_NAME
# FILTER "%stater%"
TEMPLATE querytest.html
CLASSITEM "ST"
CLASS # red
EXPRESSION /53|11|12|15|19|20|26|28|33|34|38|44|49|54|60/
SYMBOL 0
COLOR 255 153 153
END
