[mapserver-users] extent question
Vu Pham
vu at sivell.com
Wed Mar 20 12:21:29 EST 2002
Stephen Woodbridge wrote:
> The File Bounds: (MINX, MINY, MINZ, MINV)
> to (MAXX, MAXY, MAXZ, MAXV)
> and
> EXTENT MINX MINY MAXX MAXY
> This file is in UNITS DD
> (longitude, latitude)
> -Steve
Thank, Steve. Ok, I understand now. After reading some samples, I
supposed that the extent is some conversion between long/lat to some
"integer" number.
After putting those long/lat to EXTENT and adjust the UNITS to dd, this
map is displayed now.
Thanks again,
Vu
>>>Download a copy of shapelib it has utilities dbfdump and shpdump which
>>>will display info about shapefiles. shpdump will display the extents
>>>info.
>>>http://gdal.velocet.ca/projects/shapelib/index.html
>>>-Steve
>>Hi Steve,
>>Thanks. I use shpdump to dump a shp file and it says
>>Shapefile Type: Polygon # of Shapes: 51
>>File Bounds: ( -178.215, 18.925,3.75455e+072,0)
>> to ( -66.970, 71.407,0,0)
>>Shape:0 (Polygon) nVertices=276, nParts=3
>> Bounds:( -124.731, 45.543, 0, 0)
>> to ( -116.918, 49.000, 0, 0)
>> ( -122.401, 48.225, 0, 0) Ring
>> ( -122.462, 48.229, 0, 0)
>> ( -122.453, 48.129, 0, 0)
>>Am I wrong if I say these numbers are longitute and attitute ? What is
>>the relationship between extent and long/lat ?
>>Thanks again,
>>Vu
