[mapserver-users] getString(): Symbol definition error.
(6):(93)
Steve Lime
steve.lime at dnr.state.mn.us
Wed Mar 20 13:39:56 EST 2002
I don't believe there are any limitations on what the name may be.
Rather it's what the mapfile parser considers
a string.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> Pushkar Pradhan <pushkar at ERC.MsState.Edu> 03/20/02 12:32PM >>>
Steve,
I think I got it mapserver doesn't allow layer names starting with a
no. I
changed the names from 6cnty... to cnty... and it displays.
Those who didn't know this may take note of it, will save you time :-)
> Pushkar,
> Check the section just before line 96, that is where the error is.
> -Steve W.
> Pushkar Pradhan wrote:
> > Hi all,
> > I am getting the above error for a particular shape file. The layer
for
> > this file is as follows:
> > LAYER
> > NAME 6cnty_quad
> > TYPE POLYGON
> > DATA "../6cnty_quad"
> > STATUS DEFAULT
> > CLASS # every county
> > OUTLINECOLOR 28 28 28
> > COLOR 165 135 45
> > END
> > END # end of layer object - 6cnty_quad
> > I checked the name, the path also (experimented with the "" and
without).
> > The other files in this directory show up okay that means the
permiss. is
> > okay.
> > The line no. 93 refers to the LAYER statement. The type is also
polygon.
> > I've checked with colleagues and made sure the file is good. I am
out of
> > ideas please help!
> > PUSHKAR S. PRADHAN
> > Research Assistant
> > MISSISSIPPI STATE UNIVERSITY,
> > STARKVILLE, MS 39759.
> > Engineering Research Center
> > Box 9627
> > Mississippi State, MS 39762-9627
PUSHKAR S. PRADHAN
Research Assistant
Box 9627
