[mapserver-users] getString(): Symbol definition error.
(6):(93)
Steve Lime
steve.lime at dnr.state.mn.us
Wed Mar 20 13:32:27 EST 2002
A string MUST start with a-Z or is MUST be quoted. Use NAME "6cnty_quad"
to fix the problem.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> Pushkar Pradhan <pushkar at ERC.MsState.Edu> 03/20/02 12:03PM >>>
Hi all,
I am getting the above error for a particular shape file. The layer
for
this file is as follows:
LAYER
NAME 6cnty_quad
TYPE POLYGON
DATA "../6cnty_quad"
STATUS DEFAULT
CLASS # every county
OUTLINECOLOR 28 28 28
COLOR 165 135 45
END
END # end of layer object - 6cnty_quad
I checked the name, the path also (experimented with the "" and
without).
The other files in this directory show up okay that means the permiss.
is
okay.
The line no. 93 refers to the LAYER statement. The type is also
polygon.
I've checked with colleagues and made sure the file is good. I am out
of
ideas please help!
PUSHKAR S. PRADHAN
Research Assistant
MISSISSIPPI STATE UNIVERSITY,
STARKVILLE, MS 39759.
Engineering Research Center
Box 9627
Mississippi State, MS 39762-9627
