[mapserver-users] getString(): Symbol definition error. (6):(93)
Pushkar Pradhan
pushkar at ERC.MsState.Edu
Wed Mar 20 10:32:46 PST 2002
Steve,
I think I got it mapserver doesn't allow layer names starting with a no. I
changed the names from 6cnty... to cnty... and it displays.
Those who didn't know this may take note of it, will save you time :-)
> Pushkar,
> Check the section just before line 96, that is where the error is.
> -Steve W.
> Pushkar Pradhan wrote:
> > Hi all,
> > I am getting the above error for a particular shape file. The layer for
> > this file is as follows:
> > LAYER
> > NAME 6cnty_quad
> > TYPE POLYGON
> > DATA "../6cnty_quad"
> > STATUS DEFAULT
> > CLASS # every county
> > OUTLINECOLOR 28 28 28
> > COLOR 165 135 45
> > END
> > END # end of layer object - 6cnty_quad
> > I checked the name, the path also (experimented with the "" and without).
> > The other files in this directory show up okay that means the permiss. is
> > okay.
> > The line no. 93 refers to the LAYER statement. The type is also polygon.
> > I've checked with colleagues and made sure the file is good. I am out of
> > ideas please help!
> > PUSHKAR S. PRADHAN
> > Research Assistant
> > MISSISSIPPI STATE UNIVERSITY,
> > STARKVILLE, MS 39759.
> > Engineering Research Center
> > Box 9627
> > Mississippi State, MS 39762-9627
PUSHKAR S. PRADHAN
Research Assistant
Box 9627
More information about the MapServer-users
