[mapserver-users] perl module error
Dylan Keon
keon at nacse.org
Thu Mar 21 18:18:15 EST 2002
config.status indicated that I did not have gdal support compiled into
MapServer, and I'm pretty certain it also wasn't compiled into the MapScript
Perl module. However, I removed all traces of gdal from my system,
recompiled MapServer and the MapScript Perl module (making sure gdal support
was not selected), and it's now working fine. Thanks Lowell and Steve for
the replies.
--Dylan
----- Original Message -----
To: <mapserver-users at lists.gis.umn.edu>
Sent: Thursday, March 21, 2002 12:17 PM
Subject: Re: [mapserver-users] perl module error
> It appears that the code checks for a gdal flag before building in gdal
support.
> Did you compile with the --with-gdal or --with-ogr options? If so & if
there are errors could you recompile without the options and see if your
current error is related to the compile errors?
> Lowell F.
> The following message was sent by "Dylan Keon" <keon at nacse.org> on Wed, 20
Mar 2002 13:21:33 -0800.
> > There is probably an easy fix to this, but I'm stumped. I'm trying for
the
> > first time to use the MapScript Perl module in a script (use
mapscript;),
> > but I keep getting an error related to GDAL (see below). I was never
able
> > to get GDAL set up correctly, perhaps there is a lingering GDAL problem
> > that's causing this error?
> > Thanks,
> > Dylan
> > Can't load
> > '/usr/lib/perl5/site_perl/5.6.0/i586-linux/auto/mapscript/mapscript.so'
for
> > module mapscript:
> > /usr/lib/perl5/site_perl/5.6.0/i586-linux/auto/mapscript/mapscript.so:
> > undefined symbol: GDALGetRasterXSize at
> > /usr/lib/perl5/5.6.0/i586-linux/DynaLoader.pm line 200.
> > at /usr/lib/perl5/site_perl/5.6.0/i586-linux/mapscript.pm line 7
