[mapserver-users] Summary: ArcInfo TIFF byte order
Antti.Roppola at brs.gov.au
Thu Mar 21 21:52:15 EST 2002
Thanks to Frank (GDAL maintainer) for responding so
quickly with an anwser.
Further investigation showed that the default
configure used the system libtiff, and that appears
to be the source of my problem. I am using Debian
testing which has libtiff 3.5.5.
So I can either compile a new libtiff or compile
libtiff support inside GDAL and it should all work.
Cheers,
Antti
-----Original Message-----
From: Antti.Roppola at brs.gov.au [mailto:Antti.Roppola at brs.gov.au]
Sent: Wednesday, 20 March 2002 4:24 PM
To: mapserver-users at lists.gis.umn.edu
Subject: [mapserver-users] ArcInfo TIFF byte order
Interesting...
I have noticed that TIFFs I create using ArcInfo on
Solaris will not work on my x86 Linux box unless I flip
the byte order from big-endian to little-endian. This
behaviour wasn't noticed in Mapserver 3.3, which didn't
seem to care (I just check and I have a mix of both types
depending on what app produced the TIFF)
I presume this is because I am using GDAL's TIFF support
rather than Mapserver's internal TIFF support, and GDAL
is picky about byte order.
Is this the case? Or is my loading of TIFFs into Gimp doing
something else besides swapping the byte-order? I suspect not
because I can't load big-endian TIFFs that work OK in v3.3.
Cheers,
Antti
