[mapserver-users] Nationalatlas Shapefile Projection
Ed McNierney
ed at topozone.com
Thu Mar 21 23:39:21 EST 2002
Sathis -
Your EXTENT numbers are in the same units your output projection is in.
If you're displaying decimal degrees, the extents work. When you
project the output to LCC, the units change completely, and the EXTENT
numbers now specify a tiny little area that's nowhere near the United
States. That's why you get a blank image.
- Ed
Ed McNierney
Chief Mapmaker
TopoZone.com
-----Original Message-----
From: Sathiskumar Govindasamy [mailto:gsathis at yahoo.com]
Sent: Thursday, March 21, 2002 9:26 PM
To: mapserver-users at lists.gis.umn.edu
Subject: Re: [mapserver-users] Nationalatlas Shapefile Projection
Hi all,
To give a better idea about what I am trying to acheive, I have
explained little bit more in this mail than before. I wanted the
mapserver to generate the image of USA in the "lcc : Lambert Conformal
Conic projection" or "aea : Albers Equal Area" or which ever suits best
for US. I have the National Atlas US States shapefile statesp020.xxx .
The following is the map file.
NAME USA
STATUS ON
EXTENT -126 50 -66 24
UNITS METERS
SIZE 700 550
SHAPEPATH "data"
IMAGECOLOR 79 173 253
PROJECTION
"proj=lcc"
"lat_0=24"
"lat_1=50"
"lon_0=-99"
END
WEB
TEMPLATE demo.html
LOG demo.log
END
# Start of symbol definitions (we're only using a few)
SYMBOL
NAME 'circle'
TYPE ELLIPSE
POINTS 1 1 END
FILLED TRUE
END
# Start of layer definitions
LAYER
NAME statesp020
MAXSCALE 600000
TYPE POLYGON
STATUS DEFAULT
DATA statesp020
PROJECTION
"proj=latlong"
"ellps=clrk66"
END
CLASSITEM 'state'
CLASS
NAME 'Unwanted States'
EXPRESSION /'Virgin Island'|Puerto|Alaska/
OUTLINECOLOR 198 243 255
COLOR 198 243 255
END
CLASS
NAME 'State & Nation Boundary'
EXPRESSION /./
OUTLINECOLOR 180 180 180
COLOR 255 255 255
OVERLAYSYMBOL 'circle'
OVERLAYSIZE 2
OVERLAYOUTLINECOLOR 180 180 180
END
TOLERANCE 0
END
END
In the Map PROJECTION Section when I change the above shown on to
proj=latlong and remove lat_0 and other stuff, then the map shows up
correctly. But, when I have it as shown above, I just only see an image
with solid image color. Can someone tell me where I am making mistake ?
Thanks
Sathis
Kieran J. Ames wrote:
Sathis,
I'll share the little I know with you.
You need to investigate projections in general. Different projections
render
maps in different ways. If you have ArcView (what I use), you can take
your
UNPROJECTED DATA (Decimal Degrees) and PROJECT it. This will allow you
to see
what happens. If you can't do that, then you might post to the group and
ask
them what the best projection for this would be.
eg: if you want to show North America and NOT zoom in, you may choose
one
projection over another. Tell the group what you want to accomplish and
go from
there.
HTH.
Kieran
